elcectric winch.
Submitted: Monday, Jan 21, 2008 at 21:16
ThreadID: 53760 Views:2395 Replies:4 FollowUps:1
We are thinking of buying an electric winch. Has any one had any problems with either the 9500lb winch or the T-max 9,000lb winch.
Thank you Janet
Reply By: Member - Davoe (Yalgoo) - Tuesday, Jan 22, 2008 at 02:10
What sort of vehicle!
those winches would prob suit a terracan size down for a cruiser/patrol you need bigger
AnswerID: 283040
Reply By: Willem - Tuesday, Jan 22, 2008 at 08:48
I have a 9500 BRAWN which is a T MAX
The original importer for BRAWN put too much grease inside the brake mechanism and the grease went hard and stopped the brake from working properly. A mate and I pulled the winch apart, serviced it and now it is working well. They are very well made and I have used mine mainly for odd jobs around the property and also for extricating mates from serious bogs :-)
AnswerID: 283066
Reply By: Member - Alastair D (NSW) - Tuesday, Jan 22, 2008 at 09:20
Janet,
Without knowing what vehicle it is hard to say what you need but whatever you buy make sure you have a snatch block and winch extension cable and a tree protector etc. The snatch block allows doubling of the pulling power, albeit at the cost of halving the pulling distance, hence the need for extension sometimes. You can also use it to change pulling direction which is useful sometimes.
alastair
AnswerID: 283078
Reply By: ourjayco1 - Tuesday, Jan 22, 2008 at 14:03
Sorry, forget to mention that the vehicle will be a Nissan GU patrol. Hope this helps.
Janet
AnswerID: 283106
Follow Up By: Shaker - Tuesday, Jan 22, 2008 at 16:25
What bullbar do you have?
ARB say that a 12000lb winch can't be fitted with their steel winch bar, but it can be.
FollowupID: 547729
