New Zealand GU
Submitted: Tuesday, Jan 22, 2008 at 19:53
RosscoH
Does anybody know how one would go about buying a 4.2 diesel Auto GU Patrol in New Zealand and importing it into Australia, since Mr Nissan didn't do it for us.
Cheers RosscoH
Reply By: Louie the fly - Tuesday, Jan 22, 2008 at 20:15
You would have to get it complianced. Lots of companies around to do it. Where are you located?
283179
Follow Up By: RosscoH - Tuesday, Jan 22, 2008 at 20:16
Queensland
547771
Follow Up By: Louie the fly - Tuesday, Jan 22, 2008 at 20:20
This could be a good place to get info.
Importing
Don't know if the Kiwi's cars are compliant with ADR's. If so, it should be fairly easy.
547776
Follow Up By: RosscoH - Tuesday, Jan 22, 2008 at 21:16
Thanks for the link Louie, But it doesn't really tell me what I need to know about late model vehicles.
RosscoH
547787
Follow Up By: Member - Reiner G (QLD) 4124 - Tuesday, Jan 22, 2008 at 21:30
In case you are close to
Brisbane have a talk to Bruce Hartwig. Ph (07) 3255-1621
He has done a lot of engineering for us and is department of transport recommended. Easy going and no need to re-finance your house.
Good luck
Reiner
547801
Follow Up By: Rob from Cairns Offroad Training & Tours - Wednesday, Jan 23, 2008 at 10:48
I am going to NZ on 30\1\08 for a months tour while things are quiet up here in the north. I had planned to do a bit of investigation of Japanese imports of cars and bikes while I was there. I will let you know what I find out. Cheers,
Rob Berrill
Cert IV Instructor\Assessor
Accredited instructor cars\motorcycles\4wds
http://www.cairnsoffroad.com.auhttp://www.aussieat.nethttp://aussieadtours.blogspot.com/
547887
Reply By: Member - Tony W (VIC) - Tuesday, Jan 22, 2008 at 21:46
Are you sure you can get a 4.2l in NZ, there isn't one on the Nissan NZ website as an option.
283199
Follow Up By: Member - Tony W (VIC) - Tuesday, Jan 22, 2008 at 21:47
I think I just realised you mean 2nd hand.
547808
Reply By: Member - Kiwi B - Tuesday, Jan 22, 2008 at 23:36
Rossco,
Looked into this about 5 years ago and then you needed to own the vehicle in NZ for 2 years before you could bring over permanently. Could have changed now!!
Good luck,
283227
Reply By: stevesub - Wednesday, Jan 23, 2008 at 02:03
Don't bother - it is not worth it. We bought a Landrover over 5 years ago and the total cost was around $13,000 once everything was added up. If you buy a cheaper vehicle, you will end up with less tax than we did and you can opt for no insurance which will drop the bill by probably $3000.
We did own the vehicle for 2 years before we bought it from NZ, it is probably harder if you do not already own it.
Also most GU's in NZ are Jap Imports ie second hand vehicles from Japan and are less likely to meet the ADR's than new NZ vehicles.
Do your sums carefully and it will cost - do you really want one that desperately. Blame the OZ motor industry being protected by govt for the totally unrealistic import restrictions of second hand vehicles into OZ.
Would we import a vehicle again - NEVER, it is just not worth it
Stevesub
283235
Reply By: Geepeem - Wednesday, Jan 23, 2008 at 08:42
HI Rossco,
AS far as I know the rules have been tightened up about importing second hand vehicles into Australia about 18 months ago after pressure from the motor industry. The only vehicles that can be imported now must be listed on the Commonwealth Govt "Register of Specialist and Enthusiast Vehicles" OR be older than 15 years at time of importation. That is why you see a lot of the late 60 series LC from Japan over the past few years (had to be older than 15 years to come in). Some of the early 80 series are now coming in. So basically the only Patrol you can import from New Zealand would be 1992 model or older. Of course it must comply with ADR rules before it can be registered. You need to get Commonwealth Govt approval before its imported else if it doesn't comply you will have to re-export it at your expense or have it destroyed in customs. (i.e. comply with age limit or on register). ADR compliance can be done here.
I looked into it as wll but decided it was not worth it anymore.
There may be exemptions to the above rules if you owned the vehicle for a period of time in NZ and were moving to Australia for example to live. I am not sure about that side of it.
Hope this helps,
Cheers,Glen
283253
Reply By: Trevor R (QLD) - Wednesday, Jan 23, 2008 at 08:58
How would it go just buying an auto box from NZ and putting it in an Aussie 4.2, or are the auto's computer controlled??? over there?
Trevor.
283255
Follow Up By: Truckster (Vic) - Wednesday, Jan 23, 2008 at 12:00
My TD6 is being converted as we speak using a 4.5 GU auto gearbox, GQ Computer and grenade wiring loom..
It aint cheap (some quotes were $8k), and I've been fukt around by professionals..
2 week job that started November 18th, is still going with all sorts of excuses.
You cant import the GU from NZ, they were
grey imports FWIW, unless you have owned it regoed in your name, and lived in NZ with it for 12mths.
547902
