which fuse number on gu patrol
Submitted: Tuesday, Jan 22, 2008 at 20:46
Member - Vincent A M (NSW)
As I don't have my patrol book on me & 1 of my workers has changed the dash fuse today from a 10amp to a 20amp can some tell me the number of fuse (so I can put it right tonight) 2004 GU 4.2 D
Reply By: desert - Tuesday, Jan 22, 2008 at 21:52
It's marked on the fuse cover. Check the recommended amp. rating with the actual one fitted at that posi. Although, your splitting hairs over the difference a 10 makes to a 20.
283202
Follow Up By: Member - Vincent A M (NSW) - Wednesday, Jan 23, 2008 at 07:19
Thanks for the Msg but my cover has NO markings what so ever
as it works the dash instruments i would like to say with the 10amp & the fuse blow was due to a customers faulty trailer wiring
547851
Reply By: Member - Glenn D (NSW) - Tuesday, Jan 22, 2008 at 22:24
Hows it going Vincent,
On my 01 GU I have had # 15 blow before , this is a 10A fuse marked 'tail lamp'. I noticed something was wrong when I was suddendly driving as night in darkness, I guess it does all the background lights in the cabin as
well .
Hope this helps you out ,
Glenn.
283214
Follow Up By: Member - Vincent A M (NSW) - Wednesday, Jan 23, 2008 at 07:25
Glen But my fuse cover has no markings you can only go off the number & owners manual
I've now scanned & laminated the page & its in the fuse panel
547853
Follow Up By: Member - Glenn D (NSW) - Wednesday, Jan 23, 2008 at 11:46
Most right hand one third row down if you use a torch you may see numbers mouled into the black plastic of the fuse holder.
Or you could pull all the 20A fuses out one by one , or you could look for the new one.
Glenn.
547900
