What to tow with... Patrol or Cruiser
Submitted: Sunday, Jan 27, 2008 at 16:47
horse girl
Hi all,
this is my first post to the
forum, I am looking for some advice on the most suitable tow vehicle...
I have a VERY limited budget (15k) and I spend most weekends towing a big 2 horse float that weighs in at just under a tonne.... Put a couple of big horses in it and I am asking a car to drag around... and more importantly stop over 2600kg. Have electric brakes of course, but would be interested to know what you guys think is the best option for a tow vehicle and what years to avoid (looks like anything between 1990 and 1996 falls into my budget).
Horse girl.
Reply By: Member - Doug T (FNQ) - Sunday, Jan 27, 2008 at 16:51
My Daughter uses a Triton , V6 Auto , 2 horse float
283956
Follow Up By: Member - Bucky (VIC) - Sunday, Jan 27, 2008 at 18:05
I could be wrong,, but you can drag a 2 horse float behind anything, but most of the lighter utes, you can only legally have 1 horse in the float. Then Again I do live in "mexico"
I know our Navara has a 3000 kg ( braked ) limit. That should be still legal with a pair of horses, mind you I would be adding a little weight to the tray of the Navara, just to balance the load a little.
I would stick to the full blown 4 wheel drive, Cruiser/Patrol, that way you are almost as heavy as what you are towing.
Bucky
548680
Follow Up By: Member - Fred G (NSW) - Sunday, Jan 27, 2008 at 18:44
I bought my 2001 V6 petrol/lpg 3.0 ltr triton MK dual cab from a horse trainer who towed a dual horse float all over NSW, to Bris and Melb, and he replaced it with a newer one to keep on doing the same thing. I tow my caravan with it and couldn't be happier.
Nissan, Toyota, Mitsubishi, they are all good, just depends on what you fancy and your budget.
No doubt the usual this -v- that banter will be forthcoming here soon...good luck with whatever you decide to go with.
Welcome to the
Forum too :-)
548681
Reply By: Member - John (Vic) - Sunday, Jan 27, 2008 at 16:56
75 Series Troopy will tow 3500 Kgs and would be a very reliable choice.
283957
Follow Up By: horse girl - Monday, Jan 28, 2008 at 09:31
I am a big fan of the troopy.... My OH won't have a bar of it tho. He recons they are army surplus marketed to the public... LOL
I recon he is a bit of a girl... not wanting to be seen in one.
548762
Follow Up By: madfisher - Monday, Jan 28, 2008 at 14:27
In 4wd circles troopys are often seen as the ultimate 4wd.
Pete
548835
Follow Up By: Hairy (NT) - Monday, Jan 28, 2008 at 15:27
"In 4wd circles troopys are often seen as the ultimate 4wd".....
Bbwaaahhh...what a load of snot. Maybe by Troopy owners!!
HaHaHa
548848
Follow Up By: Member - John (Vic) - Monday, Jan 28, 2008 at 16:59
Hairy just remember that real men drive Troopies :-)
548859
Follow Up By: madfisher - Monday, Jan 28, 2008 at 17:31
Ha ha ha you guys crack me up . Glad to see you had a good break Hairy
Cheers Pete
548867
Follow Up By: Bonz (Vic) - Monday, Jan 28, 2008 at 18:00
"madfisher posted:
Pete"
Hahahahah only to Troopy owners, and one Landrover owner who was towed out by one hahahaha
548884
Follow Up By: Member - JohnR (Vic)&Kath - Tuesday, Jan 29, 2008 at 08:37
Bonz, wasn't one Nissan owner also towed out by one too? Just a little detail. LOL
549033
Reply By: Member - Barnesy (SA) - Sunday, Jan 27, 2008 at 17:09
Patrol 4.2 diesel 5 speed manual. Won't be fast but it will tow it all day. These Patrols have bullet proof, big and tough gearboxes, diffs and drivetrains that are stronger than the Cruiser. With regular heavy towing these are the things that take the most stress.
People regularly get 600 000km out of these 4.2 diesels. Get some top quality heavy duty
suspension and it will serve you
well. If you can find a ute with leaf rear springs even better.
The 70 series Land Cruisers would do the job also (Troopy or ute). They have leaf rear springs so will handle weight
Barnesy
283960
Reply By: Kenny Wilson - Sunday, Jan 27, 2008 at 17:18
Hi Horse girl,
do you have brake-away brake controller fitted to the trailer ?
Any Patrol , Cruiser , F250 will do the job fine
Towing vehicles unladen mass below 2000kgs should be avoided, like V6 ute with airbags. I have heard of 2 of them bend chassis just by the airbag.
283961
Follow Up By: horse girl - Sunday, Jan 27, 2008 at 17:34
Please explain (blush)
I think it is special brakes on the trailer to help it stop.... with a unit that goes in the car???
Sorry (blush)
548677
Follow Up By: Kenny Wilson - Sunday, Jan 27, 2008 at 18:45
BRAKE-SAFE ELECTRIC BREAKAWAY
trailers in excess of 2000kg if built after July 1989 must have one of these fitted
it works in conjunction with your electric brakes
548682
Follow Up By: horse girl - Monday, Jan 28, 2008 at 09:39
Thanks for the heads up there KW... I didnt even know they were mandatory.
I bet if you looked at most horse floats on the road you would find they dont have one..... My float is only 4 yo and it doesn't... and I was unaware of that requirement. An easy way to null and void your insurance cover.....
548764
Reply By: Trevor R (QLD) - Sunday, Jan 27, 2008 at 17:18
I have both a GQ 4.2 diesel Patrol and a GU 4.2 Turbo Patrol, both tow my heavy offroad van but both run hot on the temp gauge. The GQ is a slug and I am not comfortable towing long distance with it but I have been spoilt with the power in my GU.
As said the Patrols are a solid setup but so is the Cruiser. If you can find a factory turbo 80 series, I reckon that would be the go. Then it would be pretty much a dead heat between naturally aspirated Cruiser and Patrol, as to which one is better. For the 15K you may be lucky to find a high mileage turbo GU and this would also be worth a thought as 4.2 Patrols do go forever, so big k's is not so much a problem in these.
Good luck,
Trevor.
283962
Follow Up By: Member - Barnesy (SA) - Monday, Jan 28, 2008 at 12:45
The cruiser may also be solid but the g/box and other running gear on the Patrol is far stronger. Have you seen the size difference between the 2 g/boxes? Patrol is far bigger. I've heard of too many g/box problems with Toyotas.
Toyota also use the smaller Hilux front diff now. Nissan still use h/duty diff. The only things against the naturalluy aspirated Patrol is the speed, but who cares about that? As long as it gets you there.
Barnesy
548819
Follow Up By: Trevor R (QLD) - Monday, Jan 28, 2008 at 14:53
Horse Girl,
Just checked a few of the archives and it seems both GQ and 80 series have tow capacities less than that what you want to tow so look for another tow vehicle is my opinion, isurance would be void if overloaded.
Newer Cruisers and Patrols have higher tow capacities (not all of them so be careful here too).
Cheers, Trevor.
548837
Follow Up By: Off-track - Monday, Jan 28, 2008 at 18:48
Wrong Barnesy. The weak diff in recent Toyotas as you put it is only fitted in the LC100 with IFS and is not from the Hilux at all.
548900
Follow Up By: Member - Barnesy (SA) - Monday, Jan 28, 2008 at 23:59
If I'm not mistaken Offtrack, just before Toyota changed the Hilux to IFS they began putting that Hilux live axle into the 75 series Cruiser. Whereas Nissan has always kept the old-school h/duty one for the Patrol.
548996
Reply By: horse girl - Sunday, Jan 27, 2008 at 17:30
Um Errr, sorry should have mentioned must be a wagon, pretty sure they dont allow children to be chained to the back of a ute... and I wouldnt dream of doing it to my dog LOL.
283963
Follow Up By: madfisher - Sunday, Jan 27, 2008 at 18:59
Hi Horse Girl,
A very under rated vehicle are the 3.5 Jackaroos. 158kw and you can pick up low milage 98 99 s for less than $15000.00. I know I am biassed because I am wrapped in
mine. They weigh just onh 2000kg so a bit heavier tham most utes. My wife has a low milage series 11 Paj which has been very reliable but it can only just keep up with the Jack when I am towing my boat.lol
Good luck Pete
548684
Follow Up By: Trevor R (QLD) - Sunday, Jan 27, 2008 at 19:39
Madfisher is right, my wife's 3.5 petrol Jack tows our van with ease. If it was more ergonomic for me (I can't stand the seats and
suspension) I would drive this more than my GU (which is heaps) and it is an 01 model but valued at only about 9 grand. So if you sit in one of these and like it, it may just fit the bill??? rated to tow only 2500kg though but then so are the GQ PAtrols I think.
Regards, Trevor.
548688
Follow Up By: horse girl - Monday, Jan 28, 2008 at 09:41
Running to
check GQ Patrols specs.... if thats the case it is an easy decision it will be a landy....
548766
Follow Up By: Member - Oldbaz. NSW. - Monday, Jan 28, 2008 at 10:17
Must add my vote for the 3.5L Jackaroo. Big & Strong. Contrary to
rumour ,will not use a heap of fuel if driven sedately. Plenty of low
K samples around your budget. Diesel is good, but hard to justify the premium asked over petrol & then pay another 10/15 cents a litre for fuel. cheers...oldbaz.
548777
Follow Up By: Member - Barnesy (SA) - Monday, Jan 28, 2008 at 12:52
Horsegirl, be wary of manufacturer claimed towing and load capacities. I remember a few years ago (haven't checked lately)the F250 was rated to tow and carry the same as a Nissan Navara dual cab!
Basically the bigger and heavier the car the better it will tow.
548822
Follow Up By: horse girl - Monday, Jan 28, 2008 at 13:11
Please correct me if I am wrong here, because it is only my understanding that if you tow something outside the manufactures specs, it is illegal and will null and void your insurance.
So even tho something is designed and weighted to tow 4000kg, if the specs say 2500, then that is what you are limited to.... IMO there is no way I would tow with a Navara, nice ute but I would not be happy pulling the sort of weight I am going to do....
IMO it isnt about the go it is about the stop....
548824
Reply By: mrb - Sunday, Jan 27, 2008 at 21:23
We have a landcruiser 80 series 4.5 petrol /lpg tows a 1.2 tonne float and 2x 16+ hand thoroughbreds easily.
Very economical to run on lpg and not as toxic to the horses as petrol or diesel fumes.
You can get them cheap,good ones start around 10k, good value in my opinion.
Our's is a 5 speed manual but next time I'd probably go auto .
They're only $6 -800 to convert to lpg after the govt. $2000 grant and you end up with a new conversion.
I'd go for the latest year model, lowest km one you can find, there's plenty to choose from.
Anyway that's my opinion see ya.
283984
Reply By: Member - Axle - Sunday, Jan 27, 2008 at 22:02
Hi horse girl, Another vechicle to consider in your indicated price range would be a 98 model landrover tdi disco, Price would be right, Towing capability not a prob, fuel econemy Brilliant!, Reliability with that model ,as good as anything mentioned, and they are very comfy as
Cheers Axle.
283990
Follow Up By: horse girl - Monday, Jan 28, 2008 at 09:45
Without wanting to start a debate or offend Axle... I have heard more bad than good about the disco's....
Might be because unhappy customers yell louder than others......
548768
Follow Up By: madfisher - Monday, Jan 28, 2008 at 11:22
Horse girl if you can find a copy of (The dog and lemon guide) at a newsagent and see what they have to say about landies. Love them for their soul and character but to expensive to keep on the road for someone on a budget, including me.Mate in tassie who I viset every 2nd year has had 2, I am yet to rise in one as he allways has a loan car. Can you guess why.
Goodluck Pete
548805
Follow Up By: Davo_60 - Tuesday, Jan 29, 2008 at 05:55
I doubt that the Landrovers would have more reliability problems than a GU Patrol as reported on this
forum. Every day there is a new thread about some issue with the Patrols. The tdi models are very strong and the td5 are generally good too.
549024
Follow Up By: Russ n Sue - Tuesday, Jan 29, 2008 at 09:07
I'll be up front...I own a Land Rover and it has been the best 4WD I've ever owned or driven, so I guess I'm biased.
I've never owned a Landy prior to this one and have not got any personal experience with the Disco 1 or Disco 2 models but I can say this. In the 8 months I've been travelling I have come across many owners of these models and they pull some very big rigs with them. Not one of them has had a complaint about the vehicle, nor do they wish to be rid of them.
A mate of
mine has one and his theory goes like this... Landys don't hold their value, therefore very good second hand vehicles in mint condition are very cheap. He figures that you can but one of these so much cheaper than any mitsyotaniss with similar specs and k's on the clock. So he bought the Landy, pocketed the savings and was prepared to use some of those savings for repairs if needed. They weren't needed.
Like any second-hand vehicle, prudent checks by a good mechanic can save you a bundle down the track. Why not think about the Landy Disco 2 to tow the float? It has the highest rated towing capacity of any standard vehicle in its class and they aren't all lemons.
Russ
549038
Follow Up By: madfisher - Tuesday, Jan 29, 2008 at 13:18
I agree the v8s are a strong long lasdting motor(300000)ks. The 200 and 300 series mostly needed rebuilding arround 200000ks. No experience with the td5s. I believe that ford have improved Rovers quality control, about time. I have owned 2 rovers, 1 suziki, 2 toyotas, 2 jacks, and 2 rockys. I know I am a tart lol.
No where near Willems score yet.
Cheers Pete
549060
Reply By: Member - Davoe (Yalgoo) - Monday, Jan 28, 2008 at 01:08
Hmm not sure when a 4by became mandotory for towing horse floats certainly we often did it with the family sedan as did most others. Would certainly be waaay cheaper. the cheapest part about a 4by is the purchase price - its keeping it
on the road that costs
284014
Follow Up By: horse girl - Monday, Jan 28, 2008 at 09:56
Thanks Davoe,
If you can find a sedan that will tow >2750kg I will look at it.... The reason most people tow with a 4by is the towing capacity factor.
I totally agree about the upkeep.... having owned 2 4bys prior to this. I had an old SWB dsl Patrol in my 20's and recently wrote off a 95 Jeep :( . Loved the jeep but they have started making them for the masses and they are not really built to tow any more, and with the new float was going to have to upgrade it anyway.
548770
Reply By: awill4x4 - Monday, Jan 28, 2008 at 10:25
Horsegirl, where you are located and the distances you intend to travel should be a major factor in your decision making.
If you live in the suburbs of a major city and don't intend to regularly tow to the outback then lpg is probably the cheapest fuel option. If you live in country areas then diesel is the better bet.
As for vehicles, I drive an auto GQ petrol/lpg Patrol and towing my caravan it's a slug. If you decide on petrol/lpg the engine on the 80 series Landcruiser is much better for towing but the drive train (manual transmission) isn't as robust as the Nissan but the Toyota auto is a little stronger than the Patrol one.
Differentials are far stronger on the Nissan compared to the Toyota.
You could possibly pick up an early GU petrol 4.5 for somewhere close to you budget but even then it still won't perform like the Toyota 4.5 litre engine but at least the ergonomics of the car are improved compared to the earlier GQ.
Regards Andrew.
284048
Reply By: Steve from Top End Explorer Tours - Monday, Jan 28, 2008 at 13:02
Hey Horse girl.
May I suggest an 80 series diesel or a 75 series troopy diesel, both of these can be found under $15000 for a good one they will tow all day long without a problem.
Seeing you are hauling horses I don't see you towing at speed so if you tow the horse float with these cars in 4th under 90 kph you will have no problems with the Gbox as some may suggest.
I have owned 4 Troopies and 1 80 series in the last 7 years and these cars have towed trailers over several hundred thousand km on dirt corrugated roads with little or no problems.
When your finished hauling the horses they are a very capable play time car as well.
Cheers Steve
284081
Reply By: Member - JohnR (Vic)&Kath - Tuesday, Jan 29, 2008 at 08:53
Horse girl, I have a 4.2 patrol that we have towed with. On a hot day when towing the a/c can shut down to keep the engine cooler - Some Toyotas can do the same too, though I add. I now have a 100 Series to tow the Karavan with and driving it is easy :-)))
It has been suggested that Nissan diffs are unberstable which isn't correct. Mine lost quite a number of teeth last July and only ever easy towing. Getting Nissan to honour the extended warranty was like pulling teeth and took five months. Warranty Department denied the claim but Customer Services eventually allowed it.
You would find something like a GXL 100 series auto or manual is easier to drive and probably less tiring over a distance. The front diff in a Toyota is always quoted as a weakness, but if you aren't doing harder core 4bying, it shouldn't let you down.
284276
Follow Up By: Member - JohnR (Vic)&Kath - Tuesday, Jan 29, 2008 at 08:57
Sorry, shoulda read your years- budget qualification - I would look to an 80 Series diesel.
549035
