Just snapped my front wheel nut
Submitted: Monday, Jan 28, 2008 at 07:46
LZ_Pan
G'day,
Just have a quick question regarding drivability with 1 wheel nut snapped off on the front wheel, driver side. It is a 6 stud on an old hj60. Was changing
wheels this morning and it broke. Can i get around for a few days or even at all? Thx in advance. Pan.
Reply By: Member - Kiwi Kia - Monday, Jan 28, 2008 at 08:56
I would not be very concerned about it. Old trick - if you lose your wheel nuts when changeing a wheel take one nut off of each of the other
wheels.
284028
Reply By: Member - Oldbaz. NSW. - Monday, Jan 28, 2008 at 09:32
Of course you can get around safely with one missing wheel nut.
Ensure the others remain tight & you will have no problem .
cheers...oldbaz.
284037
Reply By: splits - Monday, Jan 28, 2008 at 12:46
Pan
This is a difficult question for anyone to answer. Yes you see cars running around with one nut missing and yes you can take them off other
wheels in an emergency but, while working for three Toyota dealers many years ago, I saw a few cars come in on the back of tow trucks with all six studs broken and a few other parts on the cars broken as
well.. The question with yours is why did it break?
You could have over tightened it and snapped it off but that is not easy to do on a something the size of a Landcruiser. If the stud was new you would need a long piece of pipe on the end of the wheel brace to do that. Your studs are far from new if they are the originals. This means it is more likely a combination of tightening it coupled with over twenty years of stress and metal fatigue. If that is the case then what is the condition of the remaining five and how long are they going to last now that five are doing the work of six?
If it was my car I would replace it immediately but I would also go one step further and change all 24.
Brian
284078
Reply By: BMKal - Tuesday, Jan 29, 2008 at 03:17
As splits has said, I would be at least checking, and if necessary replacing, all the wheel studs on a vehicle that age.
A common fault found on Toyotas in the mining industry is that the wheel studs corrode over time in the section that is never covered by the wheel nut (immediately outside the wheel hub). When tightened, the wheel nut never goes fully home to the hub, and over time,
water and dirt build-up at the "base" of the stud outside the hub will eventually result in corrosion. I have replaced studs in Toyotas on many occasions doe to this cause. Recently had a 79 series in for service and it was found that almost all of the studs were close to breaking.
The environment on many
mine sites, where salt
water is sprayed on the roads for dust suppression, will no doubt speed up this process, but a 60 series is not a new vehicle, so the problem could have been developing over a longer period.
This problem is not limited to Toyota either - I broke one on my Land Rover about three weeks ago.
284260
Reply By: LZ_Pan - Tuesday, Jan 29, 2008 at 13:27
Thanks everyone for your great advice. I will be replacing all the studs on the broken corner this coming sunday with the remaining 3
wheels the week after. Just wanted to assure my wife she can still drive the cruiser until then. Thanks again everyone for your time. Cheers Pan.
284305
