Hylander coupling
Submitted: Monday, Jan 28, 2008 at 08:49
jjt98
Does the Hylander coupling do the same job as Treg Hitch. It doesn't look as solid as a Treg to me. Any feed back is appreciated.
Jason
Reply By: Member - Vince B (NSW) - Monday, Jan 28, 2008 at 09:04
Hi Jason.
I have a hylander coupling on my new camper trailer. It is easier to connect the trailer up & works just as
well as the Treg.
Appears just as solid as my previous Tregg unit.
Regards.
Vince
284030
Follow Up By: jjt98 - Monday, Jan 28, 2008 at 11:13
Thanks Vince
548799
Reply By: Pezza (Bris) - Monday, Jan 28, 2008 at 10:26
Hi Jason,
If you end up wanting to buy one let me know as I have one here I didn't end up using.
Pezza
284050
Follow Up By: jjt98 - Monday, Jan 28, 2008 at 11:16
Thanks Pezza - I will let you know
548801
Reply By: Member - Brian A (NSW) - Monday, Jan 28, 2008 at 10:56
Jason,
I have one on my camper trailer. They are an excellent unit. They have all the reticulation of "all the others", plus the ease of connection of a ball coupling.
Brian
284061
Follow Up By: jjt98 - Monday, Jan 28, 2008 at 11:12
Thanks Brian
548798
Follow Up By: A J - Monday, Jan 28, 2008 at 11:33
Brian - does the Hyland coupling rattle the same as an ordinary ball coupling. With a treg you get no rattles in the coupling.
A J
548807
Follow Up By: Member - Brian A (NSW) - Monday, Jan 28, 2008 at 20:55
AJ,
there is an adjustment on the ball socket.
I've had
mine on for several thousand k's, and had no rattles.
A bit of grease and adjusted correctly.
It's great. I can't recommend highly enough.
Brian
548950
Reply By: Member - Ed. C. (QLD) - Monday, Jan 28, 2008 at 13:19
Not as solid as a Treg????
depends which one you're lookin' at, I guess;-))
Darren Hyland makes a few different versions of his excellent coupling, a pretty good comparo can be seen here >>
trailer couplings
I have the 3500.. they don't come much beefier than that:))
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
284083
Reply By: Wizard1 - Tuesday, Jan 29, 2008 at 11:03
For heaven's sake it is a HYLAND Hitch, not a Highland, Highlander, Hylander but a HYLAND.
The best thing about them, as compared to a Tregg, is the ease of hiitching (lining up is not that iimportant) and the fact you can use a standard 50mm ball.
284291
