Old caravan tyres
Submitted: Monday, Jan 28, 2008 at 16:19
Thylacine
About to replace the tyres on the old van, but sidewall info only shows "6.5 - 13". Would anyone know the correct modern equivalent?
Thanks,
ed
Reply By: Member - Graham H (QLD) - Monday, Jan 28, 2008 at 16:27
Get LT ones "Light Truck"
That figure probably is rim width 6.5 ins Diameter 13in
Go to a tyre place they will sort u out with the correct thing. Bob Janes always give me a good deal.
284114
Follow Up By: Thylacine - Monday, Jan 28, 2008 at 16:36
Ahh, thanks, but I was already
well aware of all the above.
What I wanted to know was "anyone know the correct modern equivalent?"
ed
548853
Reply By: splits - Monday, Jan 28, 2008 at 17:23
I would say about a 165 x 75 x 13. I am not sure if that is a stock size but there would be something very close to it.
Your 6.5 x 13 sounds like an old cross ply size. The 6.5 would be the overall width of the tyre walls in inches. A 6.40 x 13 was a common size on Holdens in the 1950s/60s. I suppose there was also a 6.50.
Brian
284126
Reply By: Steve Ellis - Monday, Jan 28, 2008 at 17:25
GDay Thylacine. No I dont know modern Equivalent but as the
wheels may be off an old holden or falcon you may have to get new
wheels or fit tubes. 6.5 - 13" is a holden / falcon size from way back. Millard and Viscount used them by the thousands. The old
wheels were not for tubeless tyres. I got caught with an old Viscount. The tyre
shop blokes will know. If you can get tubeless rims to fit I recomend you do so as you can fit better tyres and be safer. What you spend on the
wheels you save some by not having to buy tubes.
284128
Follow Up By: Steve Ellis - Monday, Jan 28, 2008 at 17:30
I forgot to say you can usually tell the difference between tubed and tubeless rims as the old tubed crossply rims had a very narrow shoulder compared to tubeless rims. They are also pretty narrow compared to modern tyres. Have a look at a vintage car. They all look like pushbike tyres.
548865
Reply By: madfisher - Monday, Jan 28, 2008 at 17:41
When I was a
young fella, we use to throw the old 6.40/13 tyres away and replace them with 175/13 . A 186/70/ 13 should be roughly the same height.
Cheers Pete
284135
Reply By: mowing - Monday, Jan 28, 2008 at 18:25
See if you can change the rims for 14" as it appears that the 14" tyres are more in use (cheaper) and hence easier to get.
284155
Reply By: DesF - Monday, Jan 28, 2008 at 18:48
Hi I replaced the 13'
wheels ( 6.40x13 Olympic trojan) on my Jayco with 14' rims and 185 /75 x14 x 8 ply tyres (Olympic) . got them from Beaurepairs , I think the rims were only about $20.00 each and the tyres were cheaper than 13' , lot more sold .
Cheers Des.
284162
Reply By: Thylacine - Monday, Jan 28, 2008 at 22:39
Thanks very much people.
284238
Reply By: Member - Charlie M (SA) - Tuesday, Jan 29, 2008 at 21:25
175 R 13 C Light Truck
Charlie
284387
