Solar power regulator
Submitted: Monday, Jan 28, 2008 at 19:00
ThreadID: 53980 Views:12135 Replies:4 FollowUps:18
I am worried about my solar panel set up. On the caravan we have 2/80w BP solar panels. They are connected to a BP Solar GCR 1000M regulator and 2/110 a/h gell batteries for 12 V power.
The Regulator has started to blink showing EO7 on the small screen. The graphic indicator, showing the charge state of the batteries has gone. The separate voltage meter is showing the batteries at 15-16 V. I have disconnected the batteries from the solar charging system because I am worried that the batteries are being over charged. Does anyone have any experience with this type of system.
I also have a BM-1 Battery monitor connected to the batteries.
Any help would be appreciated
Reply By: Mainey (wa) - Monday, Jan 28, 2008 at 19:56
George,
the "E07" message indicates low battery voltage.
As the SOC "graphics" no longer exists (has gone) I believe it's a malfunction with-in the LCD display, because you say you do have 15v - 16v at the battery, indicating Solar charge is definitely being delivered to the batteries, but no LCD display is showing.
First I would check all the cabling from the Solar panels right to the battery with a 'multimeter' so see where the voltage varies.
If you find no obvious problems then it's a fault with-in the LCD display.
Is it still under warranty??
Mainey . . .
AnswerID: 284183
Follow Up By: Member - George (WA) - Monday, Jan 28, 2008 at 21:11
Thanks Mainey, The regulator is only 1 week old, I will get it checked out
FollowupID: 548959
Follow Up By: disco1942 - Tuesday, Jan 29, 2008 at 01:02
With a reading of 15 V or more on your batteries there are three possibilities:
1. Your meter is US and reading too high. Measure the charge voltage on your tug as a quick confidence check.
2. The system has been incorrectly wired.
3. The regulator is faulty.
Get things checked out before you reconnect the system. Hope your batteries are not buggered, it does not take long to kill them by overcharging.
FollowupID: 549011
Follow Up By: disco1942 - Tuesday, Jan 29, 2008 at 01:22
Further to my previous, I note further down that your controller was manufactured by Steca. All of their regulators that I have come across have 3 negative terminals on them. These regulators were originally designed for telephone systems with +ve earth systems so all the circuitry has the +ve sides of it connected together.
You can only connect one of the -ve terminals to the frame (earth) of your van. This is generally the one connected to the load. If your battery or solar panels have their -ve sides grounded then you loose all current monitoring in the regulator. Check this for starters. Get this checked out by someone who knows these systems. If you are attempting to do your own wiring then re read the installation manual - several times.
FollowupID: 549015
Follow Up By: Mainey (wa) - Tuesday, Jan 29, 2008 at 08:02
In this model (Steca PR series) grounding is not required when used as a stand alone solar system with only the (-) battery terminal being grounded at the body, as is normal and usual.
2 cable connections on Left (+) & (-) Panel connection
2 cable connections in Centre (+) & (-) Battery connection
2 cable connections on Right (+) & (-) Accessories (fridge etc)
Separate Earth is not required when used with (-) grounded battery as all 'accessories' are [supposed to be] connected to (-) battery terminal.
Mainey . . .
FollowupID: 549029
Reply By: Member - BIGDOG G (WA) - Monday, Jan 28, 2008 at 21:54
Gday George,
Dont know what your running but 2x80,s and 2x110's does not sound right, I would be interested when you get expert advice.
Cheers..............BIGDOG
AnswerID: 284224
Follow Up By: Mainey (wa) - Monday, Jan 28, 2008 at 22:08
Mr Dog,
What "does not sound right" with: ""On the caravan we have 2 x 80 Watt BP solar panels, they are connected to a BP Solar GCR 1000M regulator and 2 x 110 ah gell batteries for 12v power"" ?
Mainey . . .
FollowupID: 548966
Follow Up By: Member - Mike DID - Tuesday, Jan 29, 2008 at 00:17
I don't see anything wrong with it either.
FollowupID: 548999
Reply By: MartyB - Monday, Jan 28, 2008 at 22:14
Sounds like you were sold the wrong regulator. That regulator is only rated at 10 amps. Two 80w panels will produce more than 10 amps on a good day. Take it back where you bought it from and ask for a regulator that can handle two 80 w panels. At least 15 amp regulator is needed, 20 amp prefered.
Marty.
AnswerID: 284226
Follow Up By: Mainey (wa) - Monday, Jan 28, 2008 at 22:46
Marty
the BP 80 Watt panel puts out less than 5 Amps Maximum even on a fantastic day.
The (Steca) BP reg will not have hassles even with a full 10 Amps as it has overload protection in-built.
Mainey . . .
FollowupID: 548973
Follow Up By: MartyB - Monday, Jan 28, 2008 at 23:10
Mainey,
The Telstra blue/orange panels are 80w BP Solar panels. I have seen plenty of these putting out about 5.5 amps. Some staff recon they have seen 6 amps out of these panels.
Yes I know 80w at 19v is less than 5 amps, but 80 BP solar panels definately put out more than 5 amps.
How well do you know these regulators? I don't know this model, do they have a seperate battery sense terminal? If this wire was missing it might explain this fault condition.
George, my advise would be to google for BP Solar Australia and give them a call or email. Tell them you were sold two 80 panels and a GCR 1000M regulator. Ask them if this is a recommended setup and then approach your supplier with their answer. Either way the regulator is still under warranty.
FollowupID: 548984
Follow Up By: Mainey (wa) - Monday, Jan 28, 2008 at 23:17
Marty,
they are NOT the same panel as we have posted here.
I know the Steca (BP) reg as good as anyone, it's what I *** and use too.
Mainey . . .
FollowupID: 548986
Follow Up By: Member - Mike DID - Tuesday, Jan 29, 2008 at 00:20
The short-circuit current at 75 deg C on BP380 panels is 5.0 amps.
FollowupID: 549000
Follow Up By: Mainey (wa) - Tuesday, Jan 29, 2008 at 00:26
BP 80 Watt panel specs
4.55 Amps Opperating Current
4.80 Amps Short Circuit Current
Not sure when they have changed the specs to 5 Amps??
Mainey . . .
FollowupID: 549001
Follow Up By: Member - Mike DID - Tuesday, Jan 29, 2008 at 00:39
They haven't changed the specs - read my post again :-)
FollowupID: 549007
Follow Up By: disco1942 - Tuesday, Jan 29, 2008 at 01:10
MartyB
Yes most solar pannels will put out more than their rated current on bright days with partial overcast. However your Telstra experience is with panels properly angled for the maximum output - not laid flat on a van.
FollowupID: 549012
Follow Up By: Mainey (wa) - Tuesday, Jan 29, 2008 at 09:05
Mike
According to the BP website the typical electrical characteristics for BP 380 Solar panel is:
80 Watt (rated power)
4.55 Amp (Operating Current)
4.80 Amp (Short Circuit Current)
17.60 Voltage
Standard test conditions, irradiance of 1000W/m² at an AM1.5G solar spectrum and a cell temperature of 25°C.
Normal Operating Cell Temperature, air temperature of 20°C; irradiance 800W/m²; wind speed 1m/s.
LINK:-> BP 80 Watt solar panel
So yes I'm lost as to your post as I've read it again an again :-))
I can't see where 5 Amps is mentioned - according to BP Solar.
Peter,
I don't know any Solar manufacturer that advertises power numbers that are NOT the absolute Maximum possible.
The panels are tested in state of the art labs in perfect conditions so they can advertise their panels with superior ratings to their competition.
That's why some guy's say their system does not work as well as expected lol.
Mainey . . .
FollowupID: 549037
Follow Up By: Member - Mike DID - Tuesday, Jan 29, 2008 at 09:56
Mainey - we're both right - output current increases with temperature.
"Member - Mike DID posted:
The short-circuit current at 75 deg C on BP380 panels is 5.0 amps".
- I read this short-circuit off the V-I graph, because I wanted to show the maximum possible current that BP predict from this panel.
The 4.8 amp s/c current you quoted is another measuring point taken at 25 degrees.
FollowupID: 549042
Follow Up By: Grungle - Tuesday, Jan 29, 2008 at 19:37
I have seen quite a few BP 80W panels put out more than 5.0 Amps. We do a lot of solar powered repeaters where we will get say 35 Amps from 7 x 80W panels at peak sun (one of the latest installations we have done). We have also replaced the odd 30 Amp regulator for QAS / QFRS during summer as the 6 panels they have have produced more than the regulator can handle.
I even managed 10.2 Amps from my dual 80W setup over the Australia Day weekend up at Eungella Dam. This was only for an hour at lunch but was pretty happy.
David
FollowupID: 549115
Follow Up By: MartyB - Tuesday, Jan 29, 2008 at 21:22
This discussion seems to have degenerated into whether the two panels put out slightly more or slightly less than the rating of the regulator. If I had bought this setup I would not be impressed that the regulator can only just handle the input. What happens if George wants to add another panel because the two are not handling the load. He would also have to fork out for another regulator.
My system has two 90w panels and a 20a regulator, this means my regulator is only running at about half capacity and I can easily add an extra panel.
If it was me I would be ringing BP solar and asking them if this regulator is recommended with two 80 panels.
Marty.
FollowupID: 549143
Follow Up By: disco1942 - Wednesday, Jan 30, 2008 at 00:33
Mainey
You said "Peter, I don't know any Solar manufacturer that advertises power numbers that are NOT the absolute Maximum possible."
Solar panels are rated at a radiation level that is considered to be an average of midday sun in most parts of the world. If the radiation is decreased (eg turning the panel away from the sun) you will get less output from the panel. If you increase the radiation, the panel will produce more output. There is no magic figure where if the radiation it receives exceeds a certain level the panel will not produce any more power (within certain limits.) If you do not believe me then get yourself a mirrored door (there are plenty of sliding wardrobe ones around ) and reflect more sunlight on the panel and see if its short circuit current increases. On a bright sunny day the white clouds in the sky provide that mirror. (This is also why you can get more sunburn on a cloudy day.)
It would be on these cloudy days that the Telstra techs observe outputs that are greater than the published maximum figures. The panels produce their rated power due to the direct sunlight when there is a clear patch in the clouds letting direct sunlight through and the surrounding clouds provide the mirror to direct additional radiation towards the panels.
FollowupID: 549188
Reply By: Member - George (WA) - Tuesday, Jan 29, 2008 at 21:15
Thank you everyone for your suggestions. In the end the problem was a "reset" problem and easily fixed.
1..Disconnect the negative solar connection on the regulator
2..Disconnect the negative Battery connection on the regulator
Sreen goes blank
3..Reconnect the negative solar connection
4..Reconnect the negative battery connection
The solar regulator is now reset
btw, the batteries are still OK
AnswerID: 284384
