Navara Info ??
Submitted: Tuesday, Jan 29, 2008 at 18:02
Member - craig W (NSW)
Howdy all, Wondering about when the engine size of the deisel changed?? As my oldies are looking at buying a new ute!! 07 Ute tests in several Mags state its a 2.5??But most vehicles seem to be 3 ltrs?? Is there an engine choice?? Or did it change in 08???Also whats the engine originally out off?? Or is it the same as the 3 ltre patrol??? They want an Auto as
well ,any info would be much appreciated!!
Shakey!!!
Reply By: Member - Olcoolone (S.A) - Tuesday, Jan 29, 2008 at 18:38
The older shape D22 uses a version of the 3 Lt in the Patrols.
The Newer D40 uses a new 2.5 Lt engine.
You can still buy the older D22 new as both vehicles are sold side by side.
Soon the older D22 will have the new D40 2.5 lt engine standard.
Confused????
There is no news when they are going to stop making the old D22.
Regards Richard
284348
Follow Up By: Gerhardp1 - Wednesday, Jan 30, 2008 at 00:41
They did stop making the D22.
Lost too many sales due to the high price of the D40, so the D22 will make a comeback but using the 2.5 engine, to fill the lower price gap. There could still be some new 06 plated D22s around with the 3.0l.
The 2.5 has a relatively narrow power band, requiring 6 speed gearbox to keep it in the power band.
549189
Reply By: Member - Bucky (VIC) - Wednesday, Jan 30, 2008 at 04:50
Already hearing some bad reports about the D40, ie chassis bending problem, and ground clearence,,
Give me the D22, tough as hell, probably set up as a "tradie's ute" with good 4x4 capabilities.
Cheers Bucky
284448
Reply By: PajeroTD - Wednesday, Jan 30, 2008 at 10:48
One can only hope, Nissan will put the next 3.0L V6 diesel in the Pathfinder and Navara (195kw/550Nm) give it the power it needs.
284479
Follow Up By: Member - craig W (NSW) - Wednesday, Jan 30, 2008 at 18:39
Thanks guys for the feed back, its sort of help me out??Nah only kidding!! Its cleared things up ! Now i.ll start looking..
Shakey..
549332
