Mould.
Submitted: Wednesday, Jan 30, 2008 at 22:48
Hi,I have being in
Darwin for 2months and have a small area of mould in the caravan ensuite on the ceiling, any ideas of how to remove it.Thanks.2517.
Reply By: Shaker - Wednesday, Jan 30, 2008 at 22:50
Exit Mould?? I assume it's not canvas.
284626
Reply By: Motherhen - Wednesday, Jan 30, 2008 at 23:06
Try Shower Power or one of the similar mild acid cleaners. Our en suite wall are a white smooth surface. A couple of years ago, gum leaves had collected in the partially open roof vent while parked at the house, then we got a storm which blew rain in from an unexpected direction, staining the walls with the tannin from the leaves. Shower power got them sparkling white again. There was no mould, but it works on mould in the shower in the house.
284628
Reply By: Member - Barnesy (SA) - Thursday, Jan 31, 2008 at 07:01
I used to get bad mould on a wet, cold interior house wall. I tried everything available but it kept returning. The only thing that got rid of it was ordinary household bleach.
Barnesy
284642
Reply By: Briar Tuck - Thursday, Jan 31, 2008 at 07:10
Having lived in
Darwin for 8 years One learns how to control mould successfully. Vinegar usually fixes it.
Pour some white distilled vinegar straight into a spray bottle, spray on the mouldy area, and let set without rinsing if you can put up with the smell. It will dissipate in a few hours.
Briar
284643
Reply By: Stefandsal - Thursday, Jan 31, 2008 at 09:25
Get the book Spotless from
Shannon Lush. I think there is something in there about salt
water killing mould. Bleach etc apparently doesn't kill mould, it just "bleaches" it.
284668
Reply By: Ircon - Thursday, Jan 31, 2008 at 09:37
There is a product that I have found to be the bees knees for mould and moss and does NOT contain bleach. So you can use it on a very wide variety of surfaces without fear of rotting stiching etc that can happen if the bleach is too strong.
Not cheap but goes a long long way and really works. $99.00 for 5 Litres of concentrate Mix as 5 parts
water to 1 part product (I think).
Called Wet and Forget.
http://www.wetandforget.com.au/index.htm
I have no connection to this company. I'm just a happy user.
Regards,
Rosscoe
284674
Reply By: whyallacookie - Thursday, Jan 31, 2008 at 16:22
Then go to Woolies (or your prefferred store) and buy yourself some damprid. Works a treat
284743
Reply By: 2517 - Friday, Feb 01, 2008 at 09:16
Advice.Mould.Thank very much for your help.2517.
284886
