Idling a diesel
Submitted: Friday, Feb 01, 2008 at 08:55
ThreadID: 54105 Views:3647 Replies:13 FollowUps:6
Hi folks,
I have heard numerous opinions from different people regarding idling deisel engines. Can anyone tell me whether it is bad for a diesel engine to be left idling.
I have a GU 4.2TD and always let id idle for around 10 mins before i drive off in the mornings. Am i doing damage or not?
Brett
Reply By: Member - bushfix - Friday, Feb 01, 2008 at 09:18
others more knowledgable will chip in i am sure but i believe as long as you are driving for a bit after the idle that should burn off any carbon build up in the head or cylinder glaze. If you were just to idle the vehicle at low revs regularly with not much driving (as can be the case with RFS tankers) then problems could arise I believe. You should be right I reckon but 10 mins seems excessive and I would hope it does not bother your neighbours :)
AnswerID: 284887
Reply By: Notso - Friday, Feb 01, 2008 at 09:25
Most manufacturers now recommend that you start the car and then drive off at a reasonable pace until the vehicle warms up.
With the new oils and better design of oil delivery I reckon you may as well start it and by the time you are settled in the seat with your seat belt on just drive off and don't flog it till it warms up.
AnswerID: 284889
Follow Up By: Member - Oldplodder (QLD) - Friday, Feb 01, 2008 at 09:31
Agree with notso.
Light throttle will warm the engine quicker than idling, watching the EGT. Idle is about 160 deg, light throttle is in the 200s.
Start the engine, put on seat belt, glasses etc.
By the time I get to the bottom of the street the temp gauge is starting to move.
FollowupID: 549669
Follow Up By: splits - Friday, Feb 01, 2008 at 10:47
I was taught at TAFE in the early 1960s to never warm an engine up by leaving it idling. You should drive off immediately but don't let it labour or work hard until you have driven at least about 20 to 30 ks.
About 75% of wear in an engine occurs when it is cold so the quicker you warm it up the better. This is why taxi engines last so long, they are always running at normal temperature. It is also why engines used for commuting to work over short distances or doing short trips around town for most of their life wear out much quicker. They rarely reach the correct temperature.
You must keep in mind that an engine has not reached normal temperature just because the temperature gauge says so. It is only measuring water temperature, usually in the cylinder head, and this area warms up rapidly. It takes a lot longer for parts lower down in the engine like the crank shaft, bearings, con rods, timing chains etc to reach normal temperature.
Brian
FollowupID: 549681
Reply By: Moose - Friday, Feb 01, 2008 at 10:26
It might be bad for you when an irate camper comes over and abuses you for noise and air pollution. :-)
AnswerID: 284909
Reply By: hotfishez - Friday, Feb 01, 2008 at 10:33
I travel alot and is not uncommon for me to snooze on the side of the road for anything up to an hour, vehicle running, aircon on, never had an issue myself. As for warming the vehicle up in the morning, my 79 will not achieve running temp for quite a while. Through a little research, the general rule of thumb is to get the needle off cold and dont give too much of a hard time until it has reached preffered operating temp.
AnswerID: 284910
Reply By: Gone Bush (WA) - Friday, Feb 01, 2008 at 10:37
I let mine idle while packing up the camp.
I just like the sound.
AnswerID: 284911
Follow Up By: Member - LOS BUSH - Saturday, Feb 02, 2008 at 19:37
In my School they say Do not idle a diesel without any load on the engine ie without the a/c on high. Too much running at idle will glaze the cylinders walls and reduce the engine performance
FollowupID: 550002
Reply By: Willem - Friday, Feb 01, 2008 at 10:44
It serves no purpose unless you are idling the vehicle to get a result. ie charging batteries or having a snooze in a lay-by
Its noise pollution
Its air pollution
Its annoying in Suburbia, Caravan Parks and Bush Camps.
Cjeers
AnswerID: 284912
Follow Up By: Alan H - Friday, Feb 01, 2008 at 11:13
This reminds me of the Indian Doctor who lived next door to me in the UK years ago........... frost, ice or snow he would get in his Peugot 604 start it and then rev it's guts out for about 5 minutes before driving off! The noise was horrible.
It was a new vehicle but after 12 months blew blue smoke and had dents all round as testament to his lousy driving as well.
Now I've got a neighbour who insists on leaving his V8 ute ticking over at anytime between 0530 and 0700hrs while he loads up with guttering materials for his days work, so we get a deep exhaust rumble which I would like at any other time, and a clattering of metal as he chucks it on the roof of his trailer.
There's a lot of ignorant people out there.
Alan.
FollowupID: 549687
Follow Up By: Snowbunny - Friday, Feb 01, 2008 at 14:51
Alan, I would wait till your neighbour has his next "blinder" of a bbq, friends over and all that stuff, then get up at 7am and decide to mow your lawn that morning!! Might change his tune then, sometimes its a whole lot different when the shoe is on the other foot. Then again, if your neighbour is a hells angel, dont bother with my idea.:)
FollowupID: 549714
Follow Up By: whyallacookie - Friday, Feb 01, 2008 at 16:35
Or perhaps a quiet word over a beer with him might solve the problem, he may not have even thought about it. Most people if approached politely are reasonable, otherwise perhaps discuss a change in fence?
FollowupID: 549735
Reply By: TerraFirma - Friday, Feb 01, 2008 at 11:25
Yes too much low engine rpm without a load etc etc can cause cylinder glazing and carbon build ups etc. I wouldn't worry though 10 minutes seems a long time to run an engine for nothing. You can start the engine and drive off straight away and drive slowly for the first 5 minutes as I do, if that is possible in your area..?
AnswerID: 284916
Reply By: brett patrol - Friday, Feb 01, 2008 at 11:29
Thanks for your replies. I think you hav answered my question.
By the way, i cant upset neighbours by idling my ute in the mornings as i am on 20 acres.
Much appreciated
Brett
AnswerID: 284918
Reply By: _gmd_pps - Friday, Feb 01, 2008 at 13:04
unless you have high idle switch and want to drive a PTO or charger it is useless and annoying.
good on ya for asking though and hopefully change that pollution habit in the future.
have fun
gmd
AnswerID: 284929
Reply By: Dunco (NSW) - Friday, Feb 01, 2008 at 14:52
The older engines used to have to warm up a little....and Turbo's were idled down when hot. With today's technology there is no need to warm up and engine for 10 minutes....and it annoys the crap outta me when I am sleeping in my caravan.
AnswerID: 284935
Reply By: Dunco (NSW) - Friday, Feb 01, 2008 at 14:55
AnswerID: 284936
Reply By: Member - Davoe (Yalgoo) - Friday, Feb 01, 2008 at 16:05
your nissan handbook is your freind. it will tell you the best way to warm up your vehicle is to drive off steadily and avoid full acceleration until warmed up or such like
- bet your not popular with your next door neighbours
AnswerID: 284938
Reply By: bob2 - Saturday, Feb 02, 2008 at 17:52
I have run the TD engine all night with the AC on and windows up in the tropics when mosquitos are thick and I am sleeping in the back. I have never noticed any problems.
AnswerID: 285165
