Spanner Sizes for LC100
Submitted: Sunday, Feb 03, 2008 at 11:23
ThreadID: 54174 Views:2314 Replies:3 FollowUps:6
When I go bush I take a full metric set of spanners and sockets, but I know that the 'cruiser probably needs only a relatively small number of these and I'd like to cut back.
Does anyone know the principal sizes I should carry and still be able to handle most situations?
Tom Carswell
Reply By: Mikee5 (Logan QLD) - Sunday, Feb 03, 2008 at 11:30
8, 10, 12, 14 17, 19 will get you there. Also chuck in a 13 which fits 1/2" AF for accessories such as bull bar etc.
AnswerID: 285295
Follow Up By: nowimnumberone - Sunday, Feb 03, 2008 at 12:08
10mm hex key to drain/check front diff.
24 mm socket for gearbox/transfer and rear diff.
FollowupID: 550115
Follow Up By: Steve from Top End Explorer Tours - Sunday, Feb 03, 2008 at 12:32
I've been servicing L/Cruisers for 25 years, I have never used a 10 hex key to check or drain the diffs.
Instead of a 24mm I use a 15/16 socket with the round lip ground off, this enables the socket to sit on the G/box, Transfer, and diff nuts better.
You will also need a 12mm and 14mm socket to adjust all belts, the sockets make the job easier.
If draining the Diff, G/box or Transfer loosen the filler plug first, if you can't loosen that plug do not proceed with the drain plug.
Cheers Steve.
FollowupID: 550123
Follow Up By: Member - Phil G (SA) - Sunday, Feb 03, 2008 at 12:33
add 22mm for wheelnuts and a couple of other bits
FollowupID: 550124
Follow Up By: Member - Phil G (SA) - Sunday, Feb 03, 2008 at 12:35
Steve,
the front IFS diffs need a 10mm Hex. I expect that you've just had the rigid front models.
FollowupID: 550126
Follow Up By: Member - Mike DID - Sunday, Feb 03, 2008 at 12:54
"8, 10, 12, 14, 17, 19 will get you there."
- same for a Pajero.
FollowupID: 550135
Follow Up By: Member - Davoe (Yalgoo) - Sunday, Feb 03, 2008 at 14:59
yep 15/16 is 1/2 a bees dick smaller than 24mm and has less chance of rounding off those infernal thin diff fillers.
from memory the tool kit comes with the spanners to do most jobs
FollowupID: 550184
Reply By: carswell - Sunday, Feb 03, 2008 at 12:18
Thanks chaps
Tom Carswell
AnswerID: 285310
Reply By: 96 GXL 80 series - Sunday, Feb 03, 2008 at 13:52
Oh Don't forget a 250mm socket for the nut behind the wheel :)))))))))))))))))))))))))))
AnswerID: 285335
