AnswerID: 1400 Submitted: Monday, Nov 12, 2001 at 00:00
SCOTT
replied:
Andrew very topical question. I went down this road about 2 yrs ago and my personal choice for our situation was as follows.
We chose a soft floor due to more internal space for a family of 4, and have optioned with 240v full kitchen facility attached to swing out tail
gate (includes sink storage 2 burner / griller stainless steel stove)
water tank under with steel protector. Bed base on struts to allow easy access into camper either erected or folded away, 2 large internal access under mattress. Full venterlation with windows on three sides of bed with both external and internal storm flaps also window walls with external flaps that can be used as awning. Full zip on 8ft annex that can be fully enclosed if required. The extra 2ft over standard annex of 6ft is very handy.
The trailer is 7 x 4 with 500mm sides sitting on 100mm gal/steel chasis running LT
tyres matched to vehicle with treg coupling and alco heavy duty
suspension.
We have done some 15000km now with some fairly heavy duty 4x4 including some very deep corrogations and never had any troubles. the only improvements that i intend is electric bakes and a set of dampers as it can get a bit of bounce but strangely mainly on the
outback highways at 100-110 km/h.
Depends where u are but having just moved to melb from bris the range and choice is very limited down here as opposed to qld. It also depends on your budget the above set up will set u back about $13-$15k
Hope this is of help
Reply 1 of 9
