Waeco returns from hospital..............................
Submitted: Friday, Feb 08, 2008 at 16:56
Willem
Our Waeco CF40 was released from the fridge hospital in
Port Pirie today where it had been repaired under warranty. Refer post 52418
I have just tested it and it pulled down from +24 degrees to -5 in about 30 minutes. All is
The repairer replaced the AC/DC Rectifier and the Inverter, which was broken.
Reply By: Member RayJen Paj05 (NSW) - Friday, Feb 08, 2008 at 16:57
Make sur that the power plug is always connected to the 240v, Willem...;-) Best wishes, RayJen
286385
Follow Up By: Willem - Friday, Feb 08, 2008 at 17:11
G'day Ray
Why?
551494
Follow Up By: Member RayJen Paj05 (NSW) - Friday, Feb 08, 2008 at 17:36
Remember how I plugged in yr fridge and then kicked the plug out as I left the shed?? :-((
551501
Reply By: Moose - Friday, Feb 08, 2008 at 17:24
G'day Willem
Not another fridge post :-) LOL
At least you're not asking which is the best value; has the lowest current draw; looks the prettiest; smells the best; can withstand nuclear blasts; works best in extreme temperatures etc etc.
It would be great if everyone owned a Trailblaza because then there would be no fridge posts apart from "gee my Trailblaza's bloody brilliant - it hasn't broken down in over umpteen years".
Cheers from the Moose
PS Glad it's going again but... being a Waeco, it's only a matter of time before the paramedics will be required again :-)
286387
Follow Up By: Willem - Friday, Feb 08, 2008 at 21:47
Your confidence is appreciated, Moose........lol
551570
Reply By: Member - Geoff C (QLD) - Friday, Feb 08, 2008 at 18:22
Just had
mine repaired under warranty, they upgraded the fuse. Wish Nissan were as cooperative and helpful. Booked
mine in for the recall work and decided for some reason to ring them the day before just to make sure everything was ready. They then told me that they hadn't got the part in yet. Too bad if I'd come the 20km each way for no reason. Wish they were all as easy to get along with as Waeco.
Geoff
286400
Reply By: Member - Axle - Friday, Feb 08, 2008 at 19:39
Hi Willem, A mate of
mine has just done a restoration job on a F250 Ex
ambulance, it is a brilliant thing, and just reading between the lines sometimes!, i know how you just luv F series Fords and what a place to mount The Waeco, nice soft ride etc!!
No more probs!, It will be on E-Bay soon, HAhahahaha,
Cheers Axle
286419
