Cibie Super Oscar Lights
Submitted: Sunday, Jun 15, 2003 at 01:11
ThreadID: 5451 Views:4454 Replies:3 FollowUps:2
I have a set of Cibie super Oscar Lights on my Nissan patrol
How can i clean the reflectors in the lights ??? Can I disassemble them to clean ?
Reply By: Bob Y. - Qld - Sunday, Jun 15, 2003 at 08:31
Gunnie,
Would suggest that if your reflectors need cleaning, for other than a light covering of dust, then they might be stuffed. A wipe with a soft cloth shouldn't do any harm, but any hard rubbing may lift the chrome, or put scratches into the surface.
You should be able to pull them apart, as parts were available some time back. Get some Hella 4000's, you wont be disappointed! Hooroo...
AnswerID: 22543
Follow Up By: Gunnie - Sunday, Jun 15, 2003 at 09:03
Bob Y
Yes it is just dust on the reflectors I wish to remove .
Thank you Bob Y
FollowupID: 14883
Follow Up By: Johnad - Sunday, Jun 15, 2003 at 10:11
Love my Hella 4000's - 3 years of hard work and they still burn the retinas out of insects!!!
FollowupID: 14885
Reply By: Member - DOZER- Sunday, Jun 15, 2003 at 09:10
Another way is to put some water in them, slosh it around to catch dust and empty. Do this a few times, then use metho or any other water dispersant, or simply put them out in the sun for the water to evapourate.
Andrewwheredayathinkwer mike?
AnswerID: 22545
Reply By: Stevo - Sunday, Jun 15, 2003 at 10:53
Gunnie, you cannot disassemble the lens/reflector.
Dozer has the right idea. I've cleaned Super Oscars several times by the method he desribes. Use distilled water to clean the reflector and, if need be, a soft bristled artists brush to get the dirt out from between the lens and reflector, rinse with distilled water and then meths to clean up any residual water droplets.
Like new again !!
AnswerID: 22549
