Nissan Tyre size
Submitted: Saturday, Feb 16, 2008 at 07:54
Member - John
G'day, in Post 5963 it was stated "The GU owners manual offers several other size options. VicRoads regs say it's OK to fit 15mm larger/smaller OD than the largest offered by the manufacturer for the model/series. The largest OD offered by Nissan in the owners manual is 245/85x16. This size is about 10mm smaller than 285/75/16, therefore OK. They also offer 7.50x16 in the owners manual, which are same OD as 265/75x16".
Does any one have a copy of the Nissan Owners manual that states the above? (My manual states the largest tyre size as 265/75/16 on the 16x8jj rim). Thanks in advance.
Reply By: Member - Shane D (QLD) - Saturday, Feb 16, 2008 at 09:10
Hi John,
Regardless of what it say in the manual, you will have to follow the guideline that are set out on the tyre placard on the vehicle, which is like a compliance plate , usaully around the door pillar.
This is what the authorities use for enforcement.
Shane
287736
Follow Up By: Robin Miller - Saturday, Feb 16, 2008 at 09:13
Hi Shane the authorities do use that as you say , however they are wrong and have lost at least in Victoria.
However you have to be
well armed with the facts to win in practise when pulled over on the side of the road.
553006
Reply By: Robin Miller - Saturday, Feb 16, 2008 at 09:10
My Manual specifically states that - 2002 gu , hence I have a arguement to use the 255/85/16 which is my preffered bush tyre size
287737
Reply By: Truckster (Vic) - Saturday, Feb 16, 2008 at 10:37
what about this option from a GU manual :)
287752
Follow Up By: Member - John - Saturday, Feb 16, 2008 at 22:07
Truckster, I need a photo copy of that, will ring you Monday
553131
Follow Up By: Truckster (Vic) - Saturday, Feb 16, 2008 at 22:37
I wish I had it. AJ in South Aussie gave me that scan yonks ago. Apparently you can order that glovebox book with those tire sizes in it, I think thats what he said anyway, that was yonks ago bout 18mths.
553135
Follow Up By: Truckster (Vic) - Saturday, Feb 16, 2008 at 23:49
Ok, from the poof
That is series 1 gu owners manual. That is a scan from
mine!
They deleted the 33" tyre from the mid east models Series 2 onwards. only series one handbook has it
Under the new national laws it makes 35s legal on a gu without an engineering certificate.
553156
Follow Up By: Shaker - Sunday, Feb 17, 2008 at 15:42
Right click - save picture as!
553236
Follow Up By: Truckster (Vic) - Sunday, Feb 17, 2008 at 20:54
when you find out how much john, lemme know..
maybe even try that wrecker in dande, never know ya luck!!!
553291
Reply By: Member - Ed. C. (QLD) - Saturday, Feb 16, 2008 at 23:14
John, the relevant page in my ('99) owner's manual is identical to the one posted by T-man (above)...
I'll be more than happy to scan the page and email it to you if required (M/M me with your email addy)...
Alternatively, the o/m for that year is available for purchase
here ...
Regards, Ed C
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
287854
Follow Up By: Member - John - Sunday, Feb 17, 2008 at 14:38
Ed, Thanks, I will buy the manual. John
553223
