Scanguage II
Submitted: Tuesday, Feb 19, 2008 at 17:24
Russell [SA]
Has anybody got one of these to work on Mitsubishi Pajero NL (1999).
Mine powers up but will not connect.
Russell
Reply By: KiwiAngler - Tuesday, Feb 19, 2008 at 17:27
I have a Nissan Patrol 2004 and the unit wont work on the ODB11 port. If you have another car with an ODB11 port plug it in and see if it works. If it is going to work it starts showing data within a few seconds of being connected
288315
Follow Up By: Chaz - Tuesday, Feb 19, 2008 at 22:14
Hi KiwiAngler,
Diesel Patrols aren’t OBD-II compliant, but I suspect that the later petrol models are. It should work on petrol Pathy’s and xtrails also.
Nissan’s Zexel Diesel ECU’s still use their Consult system and the only diagnostic software that I've found to work is NIStune, which communicates with my Patrol via a special interface cable. This is an excellent package for monitoring and diagnostics isn’t very expensive and works
well. Here is a
LINK to my setup.
553699
Reply By: Dunco (NSW) - Tuesday, Feb 19, 2008 at 18:13
I just purchased one today for my LC100 and it works great.
Dave from Wooders garage told me that they don't work with a lot of older cars. Go to
Scanguage web site and look there.
288323
Follow Up By: Russell [SA] - Tuesday, Feb 19, 2008 at 18:23
All research indicated it should work using protocol iso 9141 etc but obviously Mitsubishi's implementation not standard in 1999.
Russell
553634
Reply By: Member - Brad S (SA) - Tuesday, Feb 19, 2008 at 19:57
Works with Hyundai Terracans, petrol & diesel.
Try ISO and FORCE setting for Paj
288345
Follow Up By: Russell [SA] - Tuesday, Feb 19, 2008 at 20:39
Thanks, done that and tried every other protocols as
well. Did the PIDs settings as
well. Even said some norty words but still wont talk to computer.
Russell
553665
Reply By: zacc - Tuesday, Feb 19, 2008 at 20:56
does any one know if it would work on 2001 petrol pajero?
288354
Reply By: Member - Brinic (WA) - Tuesday, Feb 19, 2008 at 22:41
Does anyone know if it is possible to setup the scangaugeII to work on a 03 Toyota Prado TD
Brinic
288382
Reply By: Dunaruna - Wednesday, Feb 20, 2008 at 08:19
In north america it is LAW that every vehicle is OBD11 active, anybody can plug and play. No such law exists in Australia although many manufacturers supply the OBD11 socket. Not all sockets are active.
You need to check with the tech departments of you respective vehicle manufacturer
288408
Reply By: Russell [SA] - Wednesday, Feb 20, 2008 at 11:33
some research has returned
Abstract
Mitsubishi Motors Corporation (MMC) has developed the following new functions for diagnosing
electronically controlled systems:
• “CAN Bus Diagnosis Function” for diagnosing the controller area network (CAN) communications
bus
• “MUT-III/Pro-METS” (Multi-Use Tester III/Mitsubishi ECU Test System for Production), a software
development tool compatible with the new communications protocol “KWP*2000 on CAN”
MMC has also developed the following functions for utility applications, not limited to diagnosis:
• An ECU variant coding function to minimize ECU types
• An ID data read function to ensure parts traceability
from
http://www.mitsubishi-motors.com/corporate/about_us/technology/review/e/pdf/2004/16E_17.pdf
Russell
288422
Follow Up By: zacc - Wednesday, Feb 20, 2008 at 16:20
what does that mean in laymans talk?
553787
Follow Up By: Russell [SA] - Wednesday, Feb 20, 2008 at 17:35
In laymans terms, that question assumes I know the answer, however the instruction booklets indicates it handles protocols like
PWM CANSF ISO CANLF VPW CANSS CANSF AND KPWS, all I have to work out which one, tried them allto no avail.
I was hoping you could help.
Russell
553803
Follow Up By: Russell [SA] - Wednesday, Feb 20, 2008 at 17:36
The article is dated 2004 so might suggest it applies to MMMC cars after that.
Russell
553805
Reply By: stans truck - Wednesday, Feb 20, 2008 at 18:48
Hi all will this work on 1999 petrol 4.5lt petrol/gas landcruiser i have contacted wooders by email and they cant tell me if it would work on my 4x4 can someone advise me before i buy Regards Stan
288478
