Gas fittings
Submitted: Thursday, Feb 21, 2008 at 00:19
ThreadID: 54773 Views:2383 Replies:1 FollowUps:3
Were would one buy gas fittings . to say suit those blue long gas bottle you can buy at Bunnings ? ok not a 4x4 topic I know , but want to set up some propane gas flame trower on the caddy. Thought someone here may have set up a gas cooker system in a caravan and could help source parts .
Reply By: Louie the fly - Thursday, Feb 21, 2008 at 08:37
You should be ashamed of yourself - they're not legal you know... Anyway, I was thinking along the same lines for my Dodge sled. I actually thought of buying one of those propane single burner cookers and butchering it to get the bits I need.
If you go to an industrial fitting specialist they should be able to help with the right fittings. Try Industrial Fittings Sales at 17 Tower Crt, Noble Park, ph. 03 9706 3133. They have a huge range of fittings.
BTW, I also have a wiring diagram for a simple setup using three relays if thats of any use to you.
Kind of 4x4 related isn't it? Gas, cookers, flame throwers...
AnswerID: 288578
Follow Up By: Grizzle - Thursday, Feb 21, 2008 at 10:00
I'm sure someone advertises those things in the Unique cars Magazine. Worth a look.
FollowupID: 553942
Follow Up By: Rock Crawler - Thursday, Feb 21, 2008 at 17:55
I ready have a module to fire 2 coils , just looking at ways to get fuel in the exaust withought shutting power to endine for flooding . Gas would be the most controled wayI thought . Ill try that address, see what they say
FollowupID: 554000
Follow Up By: Louie the fly - Thursday, Feb 21, 2008 at 18:01
It's much better if you keep your engine fueled and firing as cutting the spark while it is revving apparently can wash the oil film from your cylinder walls. What model Cad?
FollowupID: 554003
