towing mirrors
Submitted: Friday, Feb 22, 2008 at 07:35
ThreadID: 54806 Views:2510 Replies:4 FollowUps:8
i have tried a couple of types but find they vibrate and wonder if their is a better one i could try
Reply By: Member - barry F (NSW) - Friday, Feb 22, 2008 at 07:47
You don't say which types you have tried. We use Aussie truck mirrors & find them pretty good.
They are available most automotive stores, they are not cheap but worth the money in my opinion. Cheers
AnswerID: 288762
Follow Up By: aka - Friday, Feb 22, 2008 at 08:06
The only ones to use $100-$ 120 each
FollowupID: 554102
Follow Up By: Nav 8 - Friday, Feb 22, 2008 at 10:49
I would second that, easy to take on and off also. Nav.
FollowupID: 554122
Follow Up By: Member - GeeTee (NT) - Friday, Feb 22, 2008 at 11:03
I'll third that ... only way to go ! !
FollowupID: 554127
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Friday, Feb 22, 2008 at 13:38
They are the ones I recommend
FollowupID: 554143
Follow Up By: Member - Fred G (NSW) - Friday, Feb 22, 2008 at 18:08
What they say....go with the
aussie truck mirrors....$220.00 a pair...Great.
Fred.
FollowupID: 554173
Follow Up By: Member - Roachie (SA) - Friday, Feb 22, 2008 at 19:01
There's a bloke selling them on ebay atm for $80- each + $15- postage for first one + $5- postage for any additional ones. You could get 2 to your door for $180-.
Roachie
FollowupID: 554183
Follow Up By: aka - Saturday, Feb 23, 2008 at 09:22
make sure they are original there are copies being sold
FollowupID: 554261
Reply By: Member - Doug T (FNQ) - Friday, Feb 22, 2008 at 09:18
This website will have all your answers
Towing Mirrors
I use these.
AnswerID: 288771
Follow Up By: turbopete - Friday, Feb 22, 2008 at 12:39
so do I,the only problem with them is that the sun detoriates the rubber straps and the straps break
FollowupID: 554135
Reply By: Member - Doug T (FNQ) - Friday, Feb 22, 2008 at 13:34
Perish..... be buggered, I've had mine for 4 years, and like yours I would presume are not on the car 24/7, I only fit them when towing,
Method, remove outside Mirror
Image Could Not Be Found
mirror fitted
For extra safety in case I fit a zip tie through the hole where the outside mirror was bolted,
AnswerID: 288805
Reply By: Member - Barnesy - Saturday, Feb 23, 2008 at 00:35
Can't remember the name of mine but they have a strap that hooks under the bottom of the door with the mirror on its own frame. They are excellent, strong, don't rattle and will last a long time.
AnswerID: 288920
