www.ExplorOz.com
Your browser does not support the site menu
Click Here
to load alternative navigation.
Latest News
Road Conditions
Updated 30/08/2008
SA Deserts
QLD Coast
Updated 29/08/2008
Top End
Adelaide and Hills
Flinders Ranges
Outback NSW
Road Conditions
All News...
Site Updates...
Search by Topic
Travelling with Babies 0 - 12 Months
4WDriving
Accessories
Accommodation
Activities
Boating
Campers & Trailers
Camping
Caravanning
Communications
Cooking
Driving Skills
Electrics
Fishing
Itineraries & Planning
Membership
Motorhomes
Navigation
Permits
PlotSwap
Recovery Gear
Servicing
Survival
Technical
Things To Do
Topics
Tours
Trek Notes
Trips with Kids
Tyres
Vehicle Choices
Visit Australia
Newsletters
Your Name
Email Address
Past Newsletters
Full Index
161
162
163
Current Users
Members
28
Customers
Visitors
18
Anon
1044
Total
1091
List...
Not Logged on
Help with battery choice
Submitted: Sunday, Feb 24, 2008 at 16:57
Member - jjt98 (QLD)
Article Overview - Battery Power
In this article we explain why you might need an additional power source independent of the starting battery installed into your vehicle and we look in detail at types of batteries, how and where to mount them, the role of isolators and the different
View Full Article...
Hi all, I'm putting a 2nd battery for the
fridge
in the vehicle & a battery for lighting etc on the CT. What battery would suite?
I have been told that a marine battery is the recommended choice for longevity & performance?
Jason
Click Image to Enlarge
Lovin' Life......Think Successful & You Will Be Successful.
(Think outside the box)
www.JasonandJodie.ws
Member:
My Profile
Advertisement
Suppress Advertisement - Members Only
AnswerID: 289139 Submitted: Sunday, Feb 24, 2008 at 17:19
Notso
replied: There's a whole heap of differing views on this, some of us use a hybrid type which is half cranker and half deep cycle I suppose is the best way to describe it. Others swear by AGMs and the marine types. Some just put a second battery the same as their main.
Probably best to get some professional advice.
Reply 1 of 10
AnswerID: 289147 Submitted: Sunday, Feb 24, 2008 at 17:46
obee
replied: I use the battery from the boat. It's there and might as well do some work while it grows old waiting for the next trip on the water.
Owen
Reply 2 of 10
AnswerID: 289148 Submitted: Sunday, Feb 24, 2008 at 17:50
Member - Lance S (VIC)
replied: jjt98, i use a trojan 27TMX deep cycle to run lights and 110lt weaco.
cheers,
Lance
Home Away from Home
Member:
My Profile
Reply 3 of 10
FollowupID: 554538 Submitted: Sunday, Feb 24, 2008 at 22:06
Member - jjt98 (QLD) posted:
Cheers Lance I'll take a look at them
Member:
My Profile
AnswerID: 289150 Submitted: Sunday, Feb 24, 2008 at 17:52
Member - Norm C (QLD)
replied: Jason, as Notso said, there are lots of opinions on this. I swear by AGM batteries. No maintenance, you can carry and use them on their side, fast charging etc. If you are not familiar with them, there is some info on them here:
Fridge and Solar AGM Info
Lots of other good info on this site also if you look around.
Norm C
To succeed in most of life's endeavours, you need a little knowledge and ability. I've got as little as anybody, so I guess I've done OK.
Norm C
Member:
My Profile
Reply 4 of 10
FollowupID: 554539 Submitted: Sunday, Feb 24, 2008 at 22:07
Thanks for the link Norm - getting some good feed back.
Jason
Member:
My Profile
AnswerID: 289174 Submitted: Sunday, Feb 24, 2008 at 19:06
Isuzumu
replied: We use the jump start/portable battery brought from super cheap 900 cranking amps around $60 it portable easy to charge and last for ages. Great to if you have a flat battery in your vehicle. We carry two and have had them both now for five years.
Also we use them for the show pump where the show tent is away from the main battery.
Cheers Bruce.
Just Muving Along
Member:
My Profile
Reply 5 of 10
AnswerID: 289182 Submitted: Sunday, Feb 24, 2008 at 19:26
Member - John and Val W (ACT)
replied: Jason,
As others have said there is a big diversity of opinion in this area. Personally I'd settle for a deep cycle, though the extra cost of a marine battery may be justified if you are going to rely on it to start the vehicle in an emergency. My view is that you should avoid carrying liquid acid inside your vehicle and camper trailer. That rules out the cheaper liquid filled batteries, so you're looking at gel or AGM, and for the larger sizes means you're looking at an AGM. These will cost.
For running the
fridge
I'd suggest a 100Ah size, though for lighting you maybe could go smaller. (My
fridge
consumes about 2/3 of my total rig demand.) To charge them you'll need heavy cable - at least twin 6mm to reach from the engine bay back to the camper trailer, and preferably bigger. An option which might be worth considering is to connect your two new batteries together with good heavy cable, so that you use them as if they are a single battery running both
fridge
and lights.
You'll need good solid anderson plugs to couple the trailer to your vehicle.
I think the main issue you'll strike trouble with is charging the batteries, especially the one in the trailer. You really need a slightly higher voltage than the alternator will normally supply, and you will have additional voltage drop in the cabling.
You mention longevity and performance. Longevity is strongly affected by how deeply you discharge your batteries and how long they are allowed to remain discharged - marine, deep cycle, cranking, this applies to all of them. Being able to fully charge them is important. I'd suggest carrying a good 3 stage charger and topping them up whenever you can. Also, carry a voltmeter and check on the charging voltages. To fully charge a battery will call for at least 14 volts at the battery terminals, 14.4 is good, or for calcium doped ones over 15V. The vehicle alternator is not intended to supply quite these voltages, and is temperature compensated to reduce the voltage to suit the cranking battery when it gets hot. My batteries rarely see more than 13.8V from the alternator, and then only when it is cold. (I carry solar panels which deliver the higher voltage required to fully charge the batteries.)
Sorry if all this sounds pretty negative, but it may save you hassles if you can learn from other people's mistakes!
HTH
John and Val.
- Albert Einstein
Member:
My Profile
Reply 6 of 10
FollowupID: 554537 Submitted: Sunday, Feb 24, 2008 at 22:05
Thanks for the advise John. Much appreciated.
Jason
Member:
My Profile
AnswerID: 289191 Submitted: Sunday, Feb 24, 2008 at 19:56
rumpig
replied: previously i had one of the hybrid cranking and deep cycle batteries for running my
fridge
. in the 2 and a half years it lasted i started my car once with it, have just changed to a 115ah deep cycle only battery, i recon the extra 35ahs this battery has will be better suited to running the
fridge
for longer periods.
Reply 7 of 10
AnswerID: 289197 Submitted: Sunday, Feb 24, 2008 at 20:13
Benno77
replied: Just as important as the battery choice is the way you are setting it up. I have a rotronics dual battery system which manages the priority of charge to the crancking battery first and takes all the guess work and human error out of the manual switch. There are a heap different brands on the market and will cost aroun $100-$300 and well worth it too.
Reply 8 of 10
FollowupID: 554540 Submitted: Sunday, Feb 24, 2008 at 22:09
Cheers.
Food for thought
Jason
Member:
My Profile
AnswerID: 289234 Submitted: Sunday, Feb 24, 2008 at 22:34
Muzzgit [WA]
replied: I have had three batteries in the patrol and I am now using an N70ZZ Exide extreme. It is a cranking/deep cycle wet lead acid type and I am very happy with it.
I previously had a wet lead acid deep cycle and I found that after being camped up for a while and the battery was reasonably well discharged it took a hell of a long time to re-charge.
Next was a sealed cranking battery, and while that one behaved much better, it didn't like the heat of the engine bay and it leaked acid down the inside of the engine bay and onto the chassis. It cost me about five hundred bucks to get everything cleaned up and re-painted.
Muzz.
I don't mind my missus having the last word, I just wish she'd get to it.
Member:
My Profile
Reply 9 of 10
AnswerID: 289245 Submitted: Monday, Feb 25, 2008 at 00:03
John S (NSW)
replied: Jason,
I went through this last year. In the end i bought an AGM 100Ah deep cycle. Cost me $320 but worth every cent. 12 months without charge and I use it every now and then for 12v power when working on the vehicles and during blackouts - it still has 11.5v charge in it.
Super fast recharge and can run my 80ltr
Waeco
& 2 Torpedo lights for two days without problems.
AGM 100Ah Deep Cycle
I've said it before, and will say it again -
bleep
Happens !! Get over it.......
Member:
My Profile
Reply 10 of 10
New/Updated
West Australian Map Book $9.95
Wildflower Country $9.95
Nissan Patrol GU Rear Door Bracket Extension $26.95
SPOT Satellite Messenger $249.00
Navy/White Racer Polo Shirt - TMTE $37.00
Mens Navy/White Polo Shirt - TMTE $31.95
Ladies Navy/White Polo Shirt - TMTE $31.95
Khaki Polo Shirt - TMTE $24.95
Fast Find
Shop Home Page
Discounted Items
Latest/Updated
All Items
Home
About Us
FAQ
Feedback
Site Stats
Membership
Advertising Campaigns
Site Updates
Forum
Blogs
Forum Archive
Trader
Shop
Treks
Places
Directory
Articles
Topics
RSS Feeds
Link to Us
Terms of Use
Corporate Membership
Privacy Policy
Copyright © 1999 - 2008,
I.T. Beyond Pty Ltd.
All rights reserved.
