I want to turbo my HJ60.... Help!
Submitted: Tuesday, Jun 17, 2003 at 03:11
marty
Can anyone tell me what the best type of turbo charger would be for my HJ60 Diesel 2H. And If anyone knows where I could get the best deal from?
Thanks a lot Marty....
Reply By: Member - Tony and Helen - Tuesday, Jun 17, 2003 at 07:10
Marty
I have recently installed a dts turbo to my hxj75 and am very happy with it
The kit was easy to install and the results are good both with economy and a massive power increase. Do a job on the thermo fan at the same time.
All the best
Tonyshe said you're
not going
down there with
me in here!
22743
Follow Up By: Member - Alex B - Tuesday, Jun 17, 2003 at 09:27
Hi Tony and Helen
How much did the dts system end up costing you (fitted)?
How many K's did you have on the motor? I have a HJ75 troopy with a 2H motor with 295K kms on the clock and have been wondering if it would be worth putting a turbo on it.
Compression is good and it runs very
well. I have been told many times that they are good for 500K+ kms but I'm a bit worried that putting a turbo on it at this age may in fact shorten it's life...Anyone have any thought or experiences?
Alex
15009
Follow Up By: marty - Tuesday, Jun 17, 2003 at 09:56
What is a dts turbo, where did you get it, how much was it? was your engine a 2H?
15011
Follow Up By: Member - Tony and Helen - Tuesday, Jun 17, 2003 at 12:24
Hi all
Dts (Dynamic turbocharger
services) I purchaced thru opposite lock and was originaly quoted $3400 after phoning arround and comparing and then talking to opposite lock again I bought the kit for $2800 and installed myself, took me about 6 hrs. 1HZ engine
The only hard part is the oil return and all seem to bash a hole in the sump and thread to take a barb which is epoxied in, personaly I would sugest removing the sump and welding a bush in place to take the oil return line
The rest is unbolting and rebolting the instructions are easy to follow.
I had 135 K in febuary on the clock when installed !! 157 K now with no problems
Also note that boost pressures are different among brands the higher the boost the more strain on parts (
mine in a 9 psi waste )
Tony
15018
Reply By: Tony - Tuesday, Jun 17, 2003 at 07:20
Marty in the long run you are better off getting a 1HZ Turbo motor out of a 80 series and putting it in.
Depends on the ks on your 2H it may need a re-build anyway.
22745
Reply By: Truckster (Vic) - Tuesday, Jun 17, 2003 at 10:53
I'd be looking at how many klms are on the motor first.
remember the lots of extra pressure a turbo puts on a motor... I wouldnt put one on a donk with 300k klms thats fer sure!
I have a Denco (www.dencodiesel.com) on my GQ, quite happy with it....
try www.google.com.au search for "toyota 2H"
Came up with this to start with.
http://www.axtturbo.com.au/toy2H.html
Some impressive figures on improvement there!!!
22767
