Opening Internet Explorer
Submitted: Wednesday, Feb 27, 2008 at 19:07
Member - Doug T (FNQ)
Quite some time ago someone was asking about how to get Webpages to open full screen instead a half screen , One of the webpages he used is EO , I too have been for months having the same problem , have to maximise the page everytime it's open , This is NOT an EO problem , it's with all webpages, so I finally decided to investigate today and found it is a default setting , If your using "NVIDIA nView Desktop Manager" below is the setting to solve the problem
Image Could Not Be Found
Reply By: Gerhardp1 - Wednesday, Feb 27, 2008 at 19:38
Sounds like a bug in your Nvidia driver.
The control you are adjusting is for using more than one monitor.
If you are only using one monitor, turn off "Enable spanning across multiple displays" and it will probably fix the issue.
In any case make sure you have the latest Nvidia driver, they update them frequently.
289691
Follow Up By: Member - Doug T (FNQ) - Wednesday, Feb 27, 2008 at 20:19
Gerhardp1
"Enable spanning across multiple displays" has nothing to do with the issue,Though I do suppose it could be turned off, It's working fine now,
The post was put up to aid others who might have the same thing happening .Not all computers will have this system .
555032
Follow Up By: Member - Doug T (FNQ) - Wednesday, Feb 27, 2008 at 20:22
Gerhardp1
I turned that feature off, it still works fine if not a little better, it don't do a little micro second flick now, Thanks .
555033
Reply By: Member - Ruth D (QLD) - Wednesday, Feb 27, 2008 at 20:11
Hello Doug and Dusty - not only from me, but from Willem, Judith and 'Jedda'. Ian's in
Quilpie.
289697
Follow Up By: Member - Doug T (FNQ) - Wednesday, Feb 27, 2008 at 20:15
Ruth, Willem, Judith and 'Jedda'. Oh and the absent Ian
Hello and Woooof'''.
555030
Reply By: TD100 - Wednesday, Feb 27, 2008 at 20:19
Hey Doug,
that could have been me,i now know that dragging the edge of the page across to the right side it opens all pages to maximum.dont know why it did it originally but i know how to sort it out now.cheers Paul
289699
Follow Up By: TD100 - Wednesday, Feb 27, 2008 at 20:24
have also done as you have shown above and apllied.Paul
555035
Follow Up By: Member - Doug T (FNQ) - Wednesday, Feb 27, 2008 at 21:42
Paul
Yeh I tried draggin' it too but after the web page was closed and re-opened ...back to half size and that was annoying on wide screen , ..no prob's now
555049
Reply By: Member - Pixie - Wednesday, Feb 27, 2008 at 21:51
i have found that windows will open in the same configuration that i last "exited" from
not clicking on the red cross but using File>Exit
289731
Follow Up By: Member - Doug T (FNQ) - Wednesday, Feb 27, 2008 at 22:24
Pixie
Noooop..Just went and put it back on default setting , done it your way , re opened windows and got half screen,Mythe BUSTED
555063
Follow Up By: Member - Pixie - Thursday, Feb 28, 2008 at 09:31
try dragging your window out to the edges (but not maximised) and File>Exit and then reopen
It may not be maximised but it will be pretty close
I can't say I have noticed any problems with minimising/maximising so I guess it must be a setting somewhere
555113
Follow Up By: Mainey (wa) - Thursday, Feb 28, 2008 at 10:16
For IO users: 'double click' on coloured (blue) header at top of window to maximise.
To return to previous size 'double click' again and it will return to original size.
That way you can 'work' in various windows all at same time.
Mainey . . .
555123
Reply By: age - Thursday, Feb 28, 2008 at 09:49
For the more game - this one gets to the root of the problem in the registry
[Start] [Run] [Regedit]
Registry Key: HKEY_CURRENT_USER\Console
Modify/Create the Value Name [FullScreen] according to the Value Data listed below.
Data Type: REG_DWORD [Dword Value] // Value Name: FullScreen
Value Data: [0 = Disabled / 1 = Enabled]
Registry Key: HKEY_CURRENT_USER\Software\Microsoft\InternetExplorer\Main
Data Type: REG_SZ [String Value] // Value Name: FullScreen
Value Data: [Modify Value to (Yes)]
Exit Registry and Reboot
A
289775
Follow Up By: Member - Pixie - Saturday, Mar 01, 2008 at 00:43
be very careful with regedit
in that area of the PC's workings you have the ability to completely stuff up your operating systemi
if you have windows XP then make a system restore point before attempting it
555484
