80w and 120w solar panels
Submitted: Wednesday, Feb 27, 2008 at 20:29
S&N
hey guys, was just wondering, is $720 + GST a good price for an 80w solar panel? it is just the panel, would have to get the regulator.
what do you think? also was quoted $1150 for a 120w panel
Reply By: Mogul - Wednesday, Feb 27, 2008 at 20:41
They seem expensive. Try on Ebay.
289707
Reply By: Jim from Best Off Road - Wednesday, Feb 27, 2008 at 20:55
Shannon,
That is not too bad, but you can do better. Call me tomorrow on 9706 6527 and I'll give you a few contacts, I don't sell them myself.
Jim.
289710
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Feb 27, 2008 at 21:07
Yes that is normal retail.
Shop around a bit and also find out if they have stock and what the delivery cost is.
Derek.
289713
Reply By: Member - Brian (WA) - Wednesday, Feb 27, 2008 at 21:21
What state. In WA you can get a BP panel $695.
I just got 2x50 Bp $890
289718
Follow Up By: Member - Brian (WA) - Wednesday, Feb 27, 2008 at 21:22
that was a 80 bp for $695
555045
Reply By: KiwiAngler - Wednesday, Feb 27, 2008 at 22:16
Depends on what you are getting for your $$. Does it have a carry bag, cables, clips, warranty etc etc
80W Solar Panels
I have one of these, purchased 2 years ago and highly recommend it
289742
Reply By: japmel - Thursday, Feb 28, 2008 at 10:13
Have a look here
85 watt Panels for $625.00 Bargin I recon.
289779
Follow Up By: Wingwang - Thursday, Feb 28, 2008 at 12:31
that is what fitted to my van with Prostar 15
my brother fitted Sharp identical wiring and reggie and Suntech push out more amps all the time
we get the solar mag at work and Suntech now num 1 world producer and Aussie owned
555136
Follow Up By: Mainey (wa) - Thursday, Feb 28, 2008 at 12:38
Wingwang,
I think you will find Suntech is number 4 "world wide"
Mainey . . .
555138
Reply By: Mainey (wa) - Thursday, Feb 28, 2008 at 12:19
price aside, you have to know what it is you are getting !!
For instance if you were offered 100 Litres of PURE
water for $100 it would be reasonable, however if that pure
water was pure WHISKY, which looks similar, it would be a real bargain.
Same with Solar panels, some perform far better than others.
The 'size' terminology used is Watts, it's only the MAXIUM available in perfect conditions.
What your NOT told is the minimum conditions required for the Solar panel to work effectively, they are more often closer to the 'normal' conditions than the 'perfect' conditions.
Just as 'oils ain't oils' Solar panels vary also.
What I'm saying is the MAXIUM Wattage is only that, the maximum wattage the panel can produce in perfect conditions, what you need to know the average wattage the panel WILL produce in low light conditions.
Cheap panels are only cheap panels !!
Mainey . . .
289795
