Site Search
Section Image
Diff Lockers - 80 Series Cruiser
Submitted: Saturday, Mar 01, 2008 at 20:21
80seriescruiser
Howdy All,
Looking at putting the ARB diff lockers on an 80 series 4.2L diesel.
I presume the front diff is the go?
My rear diff self destructed about 50,000km ago and I had a rebuild put in with LSD. I hear the cruiser LSD dies after about 50,000 kms. I did a few spinnies on some grass a while back and the LSD is still working.
I presume the ARB diff lockers are the go over Detroit etc. as its a part time 4wd and I use the cruiser as my daily around town car also. Better the ARB type you can turn off/on than the Detroit full-timers?
Any thoughts appreciated. Cheers.
Advertisement
ThreadID: 55094 Replies: 6
Views: 609 FollowUps: 9
AnswerID: 290322   Submitted: Saturday, Mar 01, 2008 at 23:15
Member - Doug T (FNQ) replied:
Seems you have not the faintest idea how a Detroit works.
Check the link and educate yourself.
Diff Locks
Also have a look at ThreadID: 54671
Click Image to Enlarge
Doug & Dusty
In the Shade
Gregory National Park
Reply 1 of 6
FollowupID: 555662   Submitted: Saturday, Mar 01, 2008 at 23:23
Leroy posted:
Seems you don't have the faintest idea how not to be rude and condescending!
Leroy
FollowUp 1 of 4
FollowupID: 555665   Submitted: Saturday, Mar 01, 2008 at 23:37
Member - Doug T (FNQ) posted:
Leroy
Mind your business, the answer was to 80seriescruiser , not you , and I'm sure he will appreciate the help, If your so smart why don't you give him some help instead annoying the crap outa me.
Doug & Dusty
In the Shade
FollowUp 2 of 4
FollowupID: 555682   Submitted: Sunday, Mar 02, 2008 at 08:52
Leroy posted:
Doug,
You're answering the question for everyone when in a public forum. I just think there's nicer ways to convey the information.
Being so smart I reviewed the links supplied and concluded there was no need for me to supply more info as what you supplied was adequate.
Leroy
FollowUp 3 of 4
FollowupID: 555716   Submitted: Sunday, Mar 02, 2008 at 13:08
Skinnydog posted:
Have read that article before and its a good one, however if you read between the lines they certainly draw attention to auto lockers limitations which are inherrent in their design whereas the main design fault with manual lockers is that they were designed for human input, so I guess once again its up to individual choice and learning to adapt to what youv'e got.
FollowUp 4 of 4
AnswerID: 290342   Submitted: Sunday, Mar 02, 2008 at 08:09
Member - Ian H (NSW) replied:
I have an 80 with part time 4wd and put a lock right locker in the front and it is great. They are actually automatic unlockers when the hubs are locked so you can't forget to disengage them but you can still get windup. They are much cheaper than other lockers and mine have been in for 130 k kms without the slightest problem. Highly reccommended gear.
When you talk you only hear something you already know.
Reply 2 of 6
AnswerID: 290382   Submitted: Sunday, Mar 02, 2008 at 12:55
Skinnydog replied:
I went with the Pro locker in the rear, been in for two years and not one problem. I think you are spot on with thinking that manual would be better than auto locker. Yes it would be good not to have to think about when to put the locker in, however I was in a mates Hilux that had auto locker in front and we got caught out by rain on a desert track which turned it slippery to boggy quite quickly. In 4wd he couldn't keep it straight due to front being locked and no way of unlocking it due to not enough load to cause the unlocking action when turning due to the slippery mud. We had to go back to 2wd which meant lots of driving until stopped and then reversing a bit and having another go at ploughing through. We were both pretty sure we woulldn't have had the problem if we could unlock front without disengaging 4wd.
PS: His next vehicle has ARB lockers front and rear and he has had no end of trouble with the O rings failing which is why I went the Pro lockers. Sometimes its good to learn from other peoples problems.
Reply 3 of 6
FollowupID: 555749   Submitted: Sunday, Mar 02, 2008 at 15:15
Patrolman Pat posted:
"In 4wd he couldn't keep it straight due to front being locked and no way of unlocking it due to not enough load to cause the unlocking action when turning due to the slippery mud."
I'm confused, he couldn't keep it straight because it wouldn't unlock whislt turning.
If traction was so compromised that there was not enough load to cause the unlocking action then it's possible that any locker would be useless anyway, they all need traction of some sort or you just sit there spinning all four wheels.
Don't follow me, I won't make it.
FollowUp 1 of 4
FollowupID: 555755   Submitted: Sunday, Mar 02, 2008 at 15:31
Wayne (NSW) posted:
Patrolman Pat,
The Hilux being "light" it would be hard for the auto locker to unlock on a muddy road.
It would have a tendency to want to go straight. Where it would have trouble is if it started to slide of the crown of the road, turning the steering wheel would have very little if any effect on the vehicle.
If it had a auto locker in the back the vehicle would still be hard to handle on a muddy road but a lot easier to steer.
Having a air locker is the best of both worlds, as long as it is in the rear. The front should only be installed and used in extreme conditions.
Wayne
Canning Stock Route 2009
Good - Better - Best
Never Let It Rest
Till Your Good Is Better
And Your Better Best
VKS Mobile 2292
FollowUp 2 of 4
FollowupID: 555756   Submitted: Sunday, Mar 02, 2008 at 15:35
Good explanation Wayne. Cheers
FollowUp 3 of 4
FollowupID: 555881   Submitted: Monday, Mar 03, 2008 at 00:07
Skinnydog posted:
Cheers from me as well Wayne, you took the words out of my keyboard exactly, while I had ducked out to a local waterhole.
FollowUp 4 of 4
AnswerID: 290386   Submitted: Sunday, Mar 02, 2008 at 13:13
Steve from Top End Explorer Tours replied:
I had front and rear Detroit lockers in my part time 4wd 80 series, they worked perfect.
Cheers Steve.
Top End Explorer ToursTop End Explorer Tours
Member: Lapsed Membership
Reply 4 of 6
Activities Index
Head & Shoulder Massage - 30 Mins Head & Shoulder Massage - 30 Mins
Adelaide - SA
Tired, fatigued and drained?
Fly Fishing Full Day for 2 Fly Fishing Full Day for 2
Snowy Mountains / Jindabyne - NSW
Fly Fishing is a great way to fish and there is nothing more relaxing than standing in a stream cast
14,000ft Tandem Skydive - Mission Beach 14,000ft Tandem Skydive - Mission Beach
Cairns and Tropical North QLD - QLD
The spectacular Coral Sea Islands provide the exhilarating views for this North Queensland skydiving
Harley Great Ocean Road Cruise For A Day Harley Great Ocean Road Cruise For A Day
Melbourne - VIC
This full day tour of the picturesque coast road of Victoria will include a stop over for lunch and
Book Now - Things To Do
AnswerID: 290394   Submitted: Sunday, Mar 02, 2008 at 14:00
Wayne (NSW) replied:
80seriescruiser,
If you are going to fit a locker to the 80 Series fit it to the back. You will get more use out of it going up and down steep hills and still allow you to steer and drive where you want.
A locker in the front will hardly be used and the vehicle was never designed to have the primary drive on the front, if it did they would have a LSD in the front as standard.
Wayne
Never Let It Rest
VKS Mobile 2292
Reply 5 of 6
AnswerID: 290514   Submitted: Sunday, Mar 02, 2008 at 23:28
80seriescruiser replied:
Thanks for the replies.
With a Lock-Right fitted to the front diff only on the 80 series, when I haven't locked the hubs in, the Lock-right's wont be turning will they?
ie. The Lock-Right is only being used when I lock in 4WD mode?
So when I am driving around in 2WD I will notice no difference in the steering performance etc?
Apologies if this sounds a novice question but trying to understand how it works.
Ta.
Reply 6 of 6
FollowupID: 555879   Submitted: Sunday, Mar 02, 2008 at 23:33
Steve from Top End Explorer Tours posted:
You wont even notice with a Detroit locker as once the hubs are unlocked the axles are not engaged the diff centre just sits there waiting to be used again.
Cheers Steve.
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
