CEM Engine Flush
Submitted: Wednesday, Mar 05, 2008 at 11:37
Member - Howard T (QLD)
After reading previous threads I have a question for those who have used this product. When the vehicle is treated with this compound there is a lot of talk of sludge being removed.
Will this sludge drain out of the hole in the sump or does the sump have to be removed and cleaned etc?
Thanks in advance
Howard.
Reply By: Rut Tearer - Wednesday, Mar 05, 2008 at 13:35
The sludge is extricated via the draining of the oil as per normal. You need to dump the oil whilst the engine is hot and as soon as you have run the treatment for the time specfied in the instructions. This is the same with all engine oil flushes as far as I know.
290891
Reply By: Keith_A (Qld) - Wednesday, Mar 05, 2008 at 19:05
Hi Howard - Used it and loved it - but I never noticed any (thick) sludge during flush. Perhaps because I always used semi syth oils, and engine only done 140k.
regards...........................Keith
290964
Follow Up By: Member - Ian H (NSW) - Wednesday, Mar 05, 2008 at 19:38
Ditto
556387
Reply By: Axel [ the real one ] - Wednesday, Mar 05, 2008 at 19:53
The old cry of "look in the archives"" ,,, seriously though ,, when I put the flush thru my 80 series it did the job as claimed ,, an 80 series turbo diesel on an oil change usually drops 9.5lt [that includes the filter] ,, when used the CEM as per instruction I got 11+ lt of the blackest crapoola oil out of the sump drain hole ,, ,, stuff works ,, ,, there is enough of the product that after the initial flush that a continuing maintenance flush using only 10% of the original is used so you get 10 more oil / filter changes ,, = 60,000 klm if u change at every 5000,, ,, can honestly say that my oil now stays Golden between changes ,, no afiliation to CEM yada yady ,ect ,,
290982
