Tow/Winch points on 80 series
Submitted: Wednesday, Mar 05, 2008 at 16:44
Member - Rodney B (NT)
I have seen some discussion on the
forum about winch or recovery points on front of 80 series. I have an ARB winch bar with two flanged tow point and I guess what is two standard tiedown points bolted into the chassis. I'm not convinced the ARB flanges are strong enough but the flanges look O'K. I tried to fit some 10000lb tow hooks but none of the holes line up in the chassis and the bull bar doesn't let you get inside even if I drill new holes. Any one had the same problem or do you use the existing tie downs ???
Reply By: Member - Rodney B (NT) - Wednesday, Mar 05, 2008 at 16:57
Ok Have found probably the best advise archived on the
forum for Troopy tie downs and
mine look as substantial as the troopy I guess, so using a bridle and stand clear looks like good advise.
290932
Reply By: Footloose - Wednesday, Mar 05, 2008 at 17:13
AFAIK someone sells the recovery points that DO line up on the 80. Do a
forum search.
290934
Reply By: GQtd42 - Wednesday, Mar 05, 2008 at 19:21
try the guys at
darwin 4wd megastore/tjm or alice if your in that area. im pretty sure i saw some there went i went throught there last year
290973
Reply By: Member - Davoe (Yalgoo) - Wednesday, Mar 05, 2008 at 20:36
People will try and tell you the loops are just tie down points. Which they may be but are plenty strong enough for any 1/2 decent recovery. There would be plenty of bogged yotas sill in the bush if they wernt
290991
