Used 100 series 315ks ???
Submitted: Tuesday, Mar 25, 2008 at 20:40
ThreadID: 55920 Views:3784 Replies:10 FollowUps:7
i am currently looking at buying a used 100 series 1hz n/a 1998 model. i have found one with high ks. what are some issues i should look out for?? it is a one owner i spoke to the previous owner, and not much has been done otherthan basic services.
I have com from GQ coil cab 4.2 ARB turbo. i will not be towing, but have plans to do tannami and cape your etc.
was consdering to turbo down the track, or should i just settle for extractors and good exhaust system??
any coments greatly appreciated!!!
Reply By: Andrew from Vivid Adventures - Tuesday, Mar 25, 2008 at 21:38
I think "settle" would be the word ;-)
Settle for a nice slow drive and enjoy the roses - unless you do the turbo, that is. But then adding turbo to a 315K specimen might add a few more complications that might slow you down.
Andrew who has done most nothing other than normal servicing to his 1HZ.
AnswerID: 294728
Reply By: Footloose - Tuesday, Mar 25, 2008 at 22:40
My 80 series is a 97 model and has 240K on it so the vehicle you're looking at has done a lotta driving. Things to look at
Radiator
Clutch fan
Clutch
Brakes
Suspension
Steering box leaks
Wheel bearings
Gearbox whine/sloppyness indicating a rebuild
Electrics
AnswerID: 294747
Reply By: Nick R (VIC) - Tuesday, Mar 25, 2008 at 22:42
I have a 60 series with only a few more kms, 2h motor with extractors, has been known to drag a gu 4.2 turbo and win. you could save a heap of $$$ and spend it on the goodies
Carpe Cerevisi
AnswerID: 294749
Follow Up By: Shane (QLD) - Thursday, Mar 27, 2008 at 16:20
Jeez ! if that's how quick the stock 60 2H is over a GU Turbo buy my 60 with a aftermarket turbo. Always thought it had a bit of go in it & only a genuine 255,000 K's. Leaves my mates 2H auto for dead. You will have a "Rocket Ship".
FollowupID: 560975
Reply By: Kiwi & "Mahindra" - Wednesday, Mar 26, 2008 at 07:54
We found a 100 series the same sort of KM a while ago...ex telstra...so everything, you would assume, would have been fixed if there was a prob while they had it.....but yours is a private sale by the sounds of it. I guess the typical oil leaks and gear box noises and whether the clutch slips etc.
good luck
Laura
AnswerID: 294781
Reply By: Von Helga - Wednesday, Mar 26, 2008 at 14:51
I have a 1999 100 series Standard wagon with every accessory you could want for sale. Could i ask what price is on yours
AnswerID: 294824
Follow Up By: rooooboy - Wednesday, Mar 26, 2008 at 19:54
he is asking $21,000.
tell me more about yours?
FollowupID: 560772
Reply By: Member - Robert G (WA) - Wednesday, Mar 26, 2008 at 19:04
We have a 1999 std LC100 in our fleet that has nearly 300k on the clock now. They have been hard kms on mines and poor gravel roads with about 80k in the Pilbara on diabolical tracks. The engine is still very strong and has never suffered any significant failure. Radiator replaced, front CV's replaced, brakes rattled apart several times, replaced suspension and steering damper, front and rear lights vibrated loose several times. The gearbox has had a whine in it for about 60k now but hasn't failed yet.
Not bad at all for the hammering it has taken. All we do is service every 5k, give it a good lube/grease and a good check for loose bits and pieces. Loctite the loose bits as you find em and they seem fine after that.
I thoroughly recomend replacing the suspension and steering damper even in a brand new LC100 as this has an incredible improvement in handling.
AnswerID: 294862
Reply By: 100 Series - Wednesday, Mar 26, 2008 at 23:36
I have a 2001 100 series base model , 190000km with MTQ turbo (turbo fitted at 90000km), 3 inch exhaust, TJM suspension, bulbar, scrub bars, BFG all terrains on GXL rims, towbar, cargo barrier, storage draws in the rear, UHF, dual batteries, logbooks, CD player, etc etc if you are interested. Best offer around 26k, the vehicle is registered until 03/09 and is in VGC. It will be on the market shortly to make way for a 200 series. The vehicle is located in QLD.
AnswerID: 294938
Follow Up By: 100 Series - Wednesday, Mar 26, 2008 at 23:44
Forgot to add, it also has an Airtec snorkel and I have owned it since it was 12 months old. If you want some pics supply your email address.
FollowupID: 560857
Follow Up By: rooooboy - Thursday, Mar 27, 2008 at 19:45
hi, do you have any photos you can email me?
FollowupID: 561009
Follow Up By: ss--ss - Thursday, Mar 27, 2008 at 20:37
this sounds like a pretty good deal
FollowupID: 561032
Reply By: rooooboy - Thursday, Mar 27, 2008 at 00:02
hi, sounds intresting plz send pics to rooooboy@yahoo.com
thanks
AnswerID: 294942
Follow Up By: 100 Series - Thursday, Mar 27, 2008 at 23:00
email sent, pictures to follow.
FollowupID: 561098
Follow Up By: 100 Series - Friday, Mar 28, 2008 at 08:50
the pictures have been sent, let me know if you receive them
FollowupID: 561146
Reply By: Member - Davoe (Yalgoo) - Thursday, Mar 27, 2008 at 01:48
21K??? tell him his dreaming
thats beyond rediculous with tht many ks
17 grand max and it would want to have plenty of extra
AnswerID: 294946
Reply By: Von Helga - Thursday, Mar 27, 2008 at 14:11
Rooooboy,
Sorry for delay in posting a reply (IT issues).
I have the car on Car Point, search for 5366662 for a look at it.
Von Helga2's
AnswerID: 294999
