Toyota 80Series diesel (non-turbo) with LPG - opinions & recommendations?
Submitted: Monday, Mar 31, 2008 at 21:56
TBudge
All,
I'm interested to hear from anyone with advice, tips and fitter/installer recommendations for possibly installing a LPG mix kit on my 80series diesel cruiser.
I've heard and read that it's basically no cost to do the conversion with the rebates ($3K?) and gives slighty lower running costs (LPG cheaper) and more power.. I'm particularly interested in the more power bit as I find the cruiser a bit sluggish up BIG hills and whilst trying to overtake (doesn't happen often but occansionally we'll pass the odd
grey nomad with van).
I've currently got the two diesel tanks (95 and 45ltr) and I believe the gas tanks get installed in the spare wheel
well under the back meaning I also need a Kaymar wheel carrier??
All tips, thoughts, advice and recommendations on reputable installers in the
Perth metro area appreciated.
cheers Tony
Reply By: Matt(WA) - Monday, Mar 31, 2008 at 23:42
Hi Tony,
I have a 97 1HZ 80 series on Diesel Gas. The car has done 175000km's. I had extractors and 2 1/2" exhaust fitted at the same time. Cost was $4500 and I got back $3000 from State and Federal governments. I would definatly not recomend the company that fitted
mine as they took an extra two days to fit, the car has been back atleast 4 times to be fixed and the original contractor that fitted the system is no longer fitting the system after screwing
mine up. It is better on fuel(about 200km's more distance) and has more power now that all the little faults have been ironed out. If you want more advice or to look at
mine and see how it all works email me: matthew.brook1@three.com.au
Hope this helps
Matt
295897
Reply By: Ray - Tuesday, Apr 01, 2008 at 10:08
You could always fit a false floor in the back as I have done. Those spare wheel carriers are expensive and can be dangerous. Have you also though of the weight lifting the spare onto the carrier?
295927
