GU Nissan Bulb Change
Submitted: Tuesday, Apr 01, 2008 at 17:15
Member - Algee (NSW)
Can anyone tell me if there is a easy way to get the bulbs out of a GU Nissan PAtrol. I cannot get in behind the lights. (no room) I am told that there may be a easy way to get the headlight to swing out from the front. Cant seem to get it to work thou.
Reply By: Tony - Tuesday, Apr 01, 2008 at 17:58
Mate, it can be done, you just need a small hand.
295982
Reply By: Member - Graham H (QLD) - Tuesday, Apr 01, 2008 at 21:09
THere is a long screw verticallyon the outer end of the headlight If u undo that the side light comes out and then u can remove the headlight.
296026
Follow Up By: Muzzgit [WA] - Tuesday, Apr 01, 2008 at 22:41
Are you shure that isn't the one that lets the indicator come out? The headlight is held in by more than one long screw.
562096
Follow Up By: Member - Duncs - Tuesday, Apr 01, 2008 at 22:43
It looks like a screw but it is not.
It is a pin just grab hold of it with some plliers and pull it up. Twisting back and
forth may help get it started.
Duncs
562098
Follow Up By: Member - Graham H (QLD) - Wednesday, Apr 02, 2008 at 05:24
That what I said It lets the indicator(side) light out then u can get at the headlight. I cant remember how many screws hold the headlight in but its not many and u have to take side light out to get at them.
Haven't had a Patrol for 2 years so a bit vague on it now.
562123
Follow Up By: Member - Algee (NSW) - Wednesday, Apr 02, 2008 at 08:43
Thanks to all I will have a go at the long screw theory and see how we go.
562138
Follow Up By: Bonz (Vic) - Sunday, Apr 06, 2008 at 00:17
I may give that theory a go tomorrow
562967
Reply By: Waynepd (NSW) - Sunday, Apr 06, 2008 at 08:32
Tony is right
If your hand is too big then find a friendly small-handed person with some strength as
well as they are a bit tough to get the wiring off especially if its the first time since new.
296926
