Site Search
Section Image
Fridge wiring requirements
Submitted: Tuesday, Apr 01, 2008 at 23:45
Gold 4.2 Patrol
I have been doing alot of research, and just a little confused and hoping for a simple response. I am wiring up for a fridge (Engel 40L) outlet, and have 6mm wire or 4.58mm2? Is this sufficient? All coming off a 2nd battery, just wire size is question.
Advertisement
ThreadID: 56174 Replies: 4
Views: 661 FollowUps: 1
AnswerID: 296088   Submitted: Wednesday, Apr 02, 2008 at 07:28
Derek from Affordable Batteries & Radiators replied:
For no more than 5m yes it is fine.
I would recommend 6mm2 but the 40L Engel will be fine.
ABR - SIDEWINDERABR - SIDEWINDER
Business Member: My Profile
Reply 1 of 4
AnswerID: 296134   Submitted: Wednesday, Apr 02, 2008 at 12:33
Keith_A (Qld) replied:
Hi Gold - the main issue is voltage drop between the battery and the fridge, and it depends on 3 things - current draw; length of cable and size (cross section) of copper in the cable.
Here is the web site that will help : Collyn Rivers and look at the article on wiring woes and also fridges.
.................Regards..........Keith.
Reply 2 of 4
AnswerID: 296208   Submitted: Wednesday, Apr 02, 2008 at 19:21
Gold 4.2 Patrol replied:
Awesome!! Thanks guys, good help, and great link. Thanks again
Reply 3 of 4
FollowupID: 562290   Submitted: Wednesday, Apr 02, 2008 at 20:11
Member - Phill E (NSW) posted:
colly rivers is the go.. copy of it below here.
There is 'rounding up' discrepancy in most published AWG/ISO conversion tables (not in mine). Use one AWG gauge size larger (ie. numerically lower) than the conversion shows. For example, ISO 2.5 is AWG 13 (not 14 as usually shown) etc. Using ISO gauges is easy. The actual gauge number (eg. 1.5, 2.5, 4.0, 6.0, 10 etc) is the actual cross sectional area of the conductor, in sq.mm.
Another very easy way to work out the voltage drop for any given length of cable, current flow, and cable size is the simple formula shown below. I always use this in conjunction with my published tables. This formula is simply:
Voltage drop equals (cable length (in metres) X current (in amps) X 0.017) divided by cable cross-section in mm.sq.
For example: 10 metres X 5 amps X 0.017 = 0.85. Divided by (say) 2.5, the voltage drop is 0.34 volt. This is just acceptable.
The above, and wire-tables indicate voltage drop across a single conductor. For chassis (earth) returns, the resistance of the return path can be ignored. Where there's another conductor for the return path, the total cable length must be taken into account. In other words, if there's a separate conductor for the earth return that's ten metres of cable, so you do the sum as if it were ten.
AnswerID: 296424   Submitted: Thursday, Apr 03, 2008 at 17:03
wheeleybin replied:
Collyn uses 0.36V drop as the basic acceptable for 12V.
5M of 4.5MM2 at 12V with a 3A load will give a voltage drop of 0.102 Give a terminal voltage at 11.898V so you have some up your sleeve.
10M of 4.5MM2 with a 3A load will give a voltage drop of 0.203 and give a terminal voltage of 0.203 so you have some up your sleeve.
The Amp load is the critical factor.
Reply 4 of 4
Activities Index
Helicopter Flight over Hervey Bay & Fraser Island Helicopter Flight over Hervey Bay & Fraser Is
Fraser Coast - QLD
Take a helicopter flight of a lifetime across the Fraser Coast.
Rally Driving Half Day (VIC) Rally Driving Half Day (VIC)
Goulburn Murray Waters - VIC
Have you ever dreamed of driving a real rally car on a real rally track?
Facial Treatment - 60 Minutes Facial Treatment - 60 Minutes
Canberra - INT
'Face' it, this is a great gift and everyone 'nose' that we're not just being 'cheeky'!
120 Minute 737 Airline Adventure 120 Minute 737 Airline Adventure
Hobart - TAS
Take a fully-fledged airline flight in the flight deck of a life-size 737 Flight Simulator.
Book Now - Things To Do
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
