heat exchanger
Submitted: Wednesday, Apr 02, 2008 at 19:44
ThreadID: 56204 Views:2583 Replies:3 FollowUps:1
G,day all,wanting to set up hot water system in my 80 series,could anyone advise which one is more efficient?Already have shurflow 11 lpm. pump fitted for water tank.
Reply By: Member - Roachie (SA) - Wednesday, Apr 02, 2008 at 19:54
Check out the Helton range...... they have different sizes and you can select where you want the inlets/outlets; I ha\ve all 4 on the same end on mine.
You can also get different sizes.....some are large enough so that you can have a good supply of hot water ready and on tap. I just have a small exchanger for the shower and it's very good indeed.
Roachie
AnswerID: 296192
Reply By: elkhound - Wednesday, Apr 02, 2008 at 20:32
thanks for the info,Roachie,have seen those, and look well made.Spending alot of time in vic high country still so not wanting to recycle water back through to shower,plus tank arrangement,how long for warm up on cold engine before use- a- billy- tee? cheers
AnswerID: 296215
Follow Up By: warfer69 - Wednesday, Apr 02, 2008 at 22:25
Nothing wrong with the Coleman Hotwater Unit,I changed the shower head to a normal one from Bunnings,a bloody ripper and portable too !
FollowupID: 562311
Reply By: madcow - Thursday, Apr 03, 2008 at 07:20
I have a Twine in my GU. But they are all pretty good, I suppose it come down to personal preference and how you wish to install it. Some are all copper some are not, some have threaded ends some do not.
there are some units and installations here
http://www.mcs.net.au/~grungle/shower.html
A friend of our has a Twine in his 80 series diesel and it is hot off idle pulling out of the streams in the high country
AnswerID: 296292
