AnswerID: 296309 Submitted: Thursday, Apr 03, 2008 at 08:33
Member - Douglas M (SA)
replied:
Hi ben_gv3.
A 5 watt hand held has the same performance as a 5 watt fixed UHF connected to the same antenna. I did a trip in 2006 with another vehicle with a similar set-up (both Uniden 5 watt hand-held connected to external antennas) and in good conditions got a range of 20 kilometres in open country near
Kununurra. The rest of the time the performance was good and we never lost contact when we were within about 5 kilometres.
There are two issues that you may wish to consider when making your decision.
1. Having a hand held radio in the vehicle connected to an external antenna, the charge cable and possibly a remote speaker-mike is a pain in the a-s.
2. Keeping the battery charged is a problem, the Uniden units must not be used to transmit while on charge, and there is no such thing as a 12 volt regulated supply for a vehicle unless you build your own or have have a 24 volt system. The chip in my charge cradle got blown either from using it in this way or from a voltage surge from the vehicle while on charge I'm not sure which. The new charge cradle was difficult to get although Uniden did manage to find one for me in the end. The alternative is to use the plug-pak that came with the radio and a 240 volt inverter (another pain). I have since bought a fixed UHF (not yet fitted and will probably ditch the hand-held.
Doug
Reply 4 of 8
