experiences with Webasto Bycool Evaporative Cooling System
Submitted: Saturday, Apr 05, 2008 at 04:16
ThreadID: 56305 Views:8208 Replies:7 FollowUps:2
hi folks,
does anyone has experiences with thouse new systems by Webasto?
Do they work just by condesating water into the air? And how does it look inside?
here s a link
Webasto Bycool
Chris
Reply By: Dave(NSW) - Saturday, Apr 05, 2008 at 09:19
Chris, They are basicly a water evaporative cooler and not real good in high humidity areas, Have used a different brand same principle in my truck and not real impressed.Refrigerated ones are 100% better
Cheers Dave....
GU RULES!!
AnswerID: 296758
Reply By: Chris@forum - Saturday, Apr 05, 2008 at 10:36
hi Dave
which refrigerated would you consider as best energy effective?
Point is they need a generator, which would made the effort to big for a small slideon camper.
better stay with the ventlators than
Chris
AnswerID: 296769
Reply By: Member - Olcoolone (S.A) - Sunday, Apr 06, 2008 at 23:11
Been around for about 3 years on the Aussie market.
Why do you want one of these and not a refrigerated type.
Works the same as evaporative types in houses.
The cost about the same as refrigerated reverse cycle.
Regards Richard
AnswerID: 297082
Reply By: Member - Davoe (Yalgoo) - Monday, Apr 07, 2008 at 00:02
How much water do they use?
evaps can use a fair bit which can be a real PITA
AnswerID: 297091
Reply By: Chris@forum - Monday, Apr 07, 2008 at 05:21
simply refrigerated system suck to much energy for battery/solar systems. As far as I know, aircondition is not possible without generator
AnswerID: 297097
Follow Up By: Member - JohnR (Vic)&Kath - Monday, Apr 07, 2008 at 09:12
They all take a minimum of a EU20i Honda Chris. Have a Dometic 1900 in the Karavan and that is a pretty small one. A fan is about the only option.
The point above about the water required for the evaporative a/c is a warning though, as no matter what you will have extra weight which is tough for a slide-on. It is better to go without until you can carry more as we found out. People with trailers and caravans or Karavans do carry or take more.
FollowupID: 563141
Reply By: Chris@forum - Monday, Apr 07, 2008 at 21:45
thanks John
as I understand its really about getting humidity in the air and
working with circulating. That really dosn't work in tropical areas, by using a ventilator you have the same effect there.
You are right, extra weight through water is a point.
here are a few smaller compressor ones I found:
Dometic B 1100 S
Waeco CoolAir CA-1000
SAPHIR COMPACT
SUNNY AIRCO 2000
--- and other brads
SILENT BIPOWER 7000 H TELAIR
ICEBERG 5012 12V
FROSTAIR 1700
Waeco EASY COOL EC1500 heating + cooling
DUAL - POWER 1
and i found supercool.se M2-12-MCD thermo electric used for emergecy vehicles and yachting, thermo electrical
how ever this might work, it looks interesting
Chris
AnswerID: 297289
Follow Up By: Chris@forum - Monday, Apr 07, 2008 at 21:50
here is a direct link
FollowupID: 563291
Reply By: Chris@forum - Monday, Apr 07, 2008 at 22:25
ups, that was a mistace
forget about the supercool s, that is coolbox cooling !!!
AnswerID: 297302
