leaking fuel pump
Submitted: Saturday, Apr 05, 2008 at 21:25
Member - morry H (WA)
hi can anyone recomend a good work
shop that can reseal my fuel pump on my 1989 gq safari 4.2 diesel ,and then set it up
in or around
perth
regards morry
Reply By: d04 - Saturday, Apr 05, 2008 at 21:48
Turbo Tech or
United diesel both in gt eastern hwy Redcliff
296868
Reply By: autosparky - Sunday, Apr 06, 2008 at 12:56
total fuel injection
services macadam place balcatta
296964
Follow Up By: Member - morry H (WA) - Sunday, Apr 06, 2008 at 22:29
thanks for that will get to them tomorrow . today i put 1ltr of chem teck in fuel
tank went for a 30 klm run and it has stoped at the moment but it will need to be done . a leaking fuel pump is like death and taxes it will happen but when???????????
regards morry
563112
Reply By: autosparky - Sunday, Apr 06, 2008 at 22:45
ask for kim ex boss 92404800 3/10 macadam pl balcatta
297078
Follow Up By: Member - morry H (WA) - Tuesday, Apr 08, 2008 at 21:57
hi any one who is interested as you have read i have had a problem with a leaking fuel pump on my gq safari with a 4.2 diesel. This also has the latest D Gas and the denco turbo charger fitted. Friday the fuel pump started to leak big time at
the governor cover as i am going away in 7 days big panic with a half
tank of fuel i put half litre chemtek in
tank.
I have driven 60 kls so far and the leak has stopped to a point where i can go away and take the risk only going to
westonia any way a long winded story but it seems that fuel aditives do work in fuel as
well automatics which i have success any way fingers crossed.
563468
Reply By: autosparky - Tuesday, Apr 08, 2008 at 23:06
morry chemicals have a finite life , diesel is in fact a chemical, please as a fuel ihjection apprentice and a trdes men in an earlier time you cannot replace a metal that has worn out with a chemical it is temporary at best and you can only court danger with extended use . injector cleaners only clean , they do not replace worn injector nozzles ! it sounds like all you need is a seal and new bush replaced on the throttle shaft . for peace of mindreplace these components. dont rely on finding another bottle of a chemicle to replace an already damaged seal
297485
