Cleaning Suburban HWS
Submitted: Sunday, Apr 06, 2008 at 17:16
Russell [SA]
When I got to check my HWS for the first time (1 month after purchase of 12month old van) found the anode nearly totally gone and the bottom on the
tank covered in white calcium like deposits. I used my fingers and tried to flush as as much out as I could and after spending as much time as I could I reassembled with a new anode and dried my self off. The question is could/should I use some CLR in the
tank to try and clean it or not?
Russell
Reply By: Rock Ape - Sunday, Apr 06, 2008 at 17:36
Pull it out and remove the element, use a high pressure
water blaster to remove the calicum. You won't hurt the enamel and much faster than anything else.
297005
Reply By: Dunaruna - Sunday, Apr 06, 2008 at 18:44
The calcium carbonate is an unfortunate fact of life, a yearly flush/clean should do the trick.
The anode is another story, they should last longer than 12 months, me thinks you have a grounding problem. Is the model a manual L.P.G, auto L.P.G or L.P.G/240v ?
297013
Follow Up By: Russell [SA] - Sunday, Apr 06, 2008 at 19:34
Answer: LPG/240v.
I have been told an anode not likely to last 6 months depending on
water quality. Am mostly in SA and the anode was looking pretty sick after 12 months.
Russell
563068
Follow Up By: Dunaruna - Sunday, Apr 06, 2008 at 20:05
Yes, that is true.
Is it possible to drain the
tank when the van is laidup.
563075
Reply By: Member No 1- Monday, Apr 07, 2008 at 07:34
sounds like its doing what its supposed to be.....thats why they call them a sacrificial anode...they corrode away instead of your heater....depending on the quality of
water its longevity cannot be determined...
adelaide water wont let em last long
297108
