All locked up and some where to go
Submitted: Sunday, Apr 06, 2008 at 19:47
ThreadID: 56373 Views:2255 Replies:7 FollowUps:3
For some time now I've received a ribbing from my mates due to fact that everything in the car is under lock and key (why make it easy for the buggars). Sounds good in theory, provided you don't lose the key.
The offending lock is attached to the camper trailer hitch in this instance.
After much searching for the key, the angle grinder came out, only to discover the lock was inaccessible to the blade.
I sat down and had a look at the thing, then decided to attack it with the bolt cutters to no avail.
It appears there are only two solutions. Either call in a Locksmith or grind off the locking frame.
Any other Ideas?
Kim
Reply By: Member - Happy Gutz (QLD) - Sunday, Apr 06, 2008 at 19:53
Gas axe mate
AnswerID: 297029
Reply By: Member - Stuart W (NSW) - Sunday, Apr 06, 2008 at 19:54
If it's a brass bodied padlock use an 18'' shifter or smaller shifter and pipe and twist the body.The brass around where it connects with the bolt will break.
Stuart
AnswerID: 297030
Follow Up By: Member - Kim M (VIC) - Sunday, Apr 06, 2008 at 20:10
Stuart
Thanks for that. I'll grab a larger shifter from work tomorrow and give it a go.
Kim
FollowupID: 563076
Follow Up By: Member - Stuart W (NSW) - Sunday, Apr 06, 2008 at 20:14
no worries Kim. A bloke showed me this a couple of years ago at work after someone lost the keys to a dozen padlocks. I have'nt bought a brass padlock since.
Stuart
FollowupID: 563079
Reply By: Member - Glenn G (QLD) - Sunday, Apr 06, 2008 at 19:58
There is a third solution ! Find the key :) LOL Its sunday and had a few cordials !
Giffo
AnswerID: 297032
Reply By: Member - Axle - Sunday, Apr 06, 2008 at 19:59
Bigger Hammer Mate!!!!.
Cheers Axle.
AnswerID: 297033
Reply By: Member - Happy Gutz (QLD) - Sunday, Apr 06, 2008 at 20:00
Gas axe mate
AnswerID: 297034
Reply By: Member - Happy Gutz (QLD) - Sunday, Apr 06, 2008 at 20:02
Whoops, posted twice. Dummy
AnswerID: 297035
Reply By: mowing - Sunday, Apr 06, 2008 at 23:48
Kim, At least it shows that you have achieved what you set out to do!!
Mark
AnswerID: 297088
Follow Up By: Member - Kim M (VIC) - Monday, Apr 07, 2008 at 18:52
Mark
Just go's to show we can be too smart for our good at times.
LOL
Kim
FollowupID: 563239
