Navara Screeching
Submitted: Monday, Apr 07, 2008 at 10:54
ThreadID: 56390 Views:2145 Replies:6 FollowUps:9
Hi all, our daughter has a 2002 Navara, the problem is when it is running there is a terrible screeching coming from the front, we think it may have something to do with the fan belt as when it is running and we spray it the screeching stops for a bit and then starts up again. All pulleys and bearings have been checked and are OK, the belt has been changed but the same thing occurs. Has anybody had this problem or know how we can fix it.
D
Simba, our much missed baby.
Reply By: lakedge - Monday, Apr 07, 2008 at 14:04
Sounds very much like the same problem we had with a near new Hilux . ( Refer post Jan or Feb screeching Hilux)Turned out to be the water pump dust seal. Hard to find as intermittent. Dealer diagnosed with stethoscope - you might try with a big screwdriver to the ear, I think best the pointy end not to the ear, and be very careful of moving pulleys, fans and belts.
Regards, John.
BTW Brian Hilton Toyota Gosford very helpful - not connected with them but dealers get some deservedly bad press here at times, so a good rap occasionally is warranted.
AnswerID: 297172
Follow Up By: Member - Dunworkin (WA) - Monday, Apr 07, 2008 at 14:42
Thanks for that John, it's definitely somewhere to start, It does sound like the water pump but that has been checked out but will look at the dust seal.
D
FollowupID: 563181
Reply By: Member - David P (VIC) - Monday, Apr 07, 2008 at 15:33
V or ww type pulleys and belt?...silverback
AnswerID: 297187
Follow Up By: Member - Dunworkin (WA) - Monday, Apr 07, 2008 at 16:02
Hi silverback, sorry but I'm very ignorant on these matters and not quite sure what you mean, I know what a v belt is but not a ww, the only thing I know is that it is the drive belt, when it gets sprayed it stops for a while and then starts up again.
D
FollowupID: 563211
Follow Up By: Member - David P (VIC) - Monday, Apr 07, 2008 at 16:13
the ww belt is a wider but thinner belt with a multi ribbed vvvv looking under side, it flexes more easily,generating less belt heat and stress and much less likely to squeal, a much more modern belt and I would have thought it would be what you have...silverback
FollowupID: 563215
Follow Up By: Member - Dunworkin (WA) - Monday, Apr 07, 2008 at 16:26
yeah that is what it is and I thought that was what you were asking but wasn't sure, it is a much wider belt than your normal v belt.
D
FollowupID: 563218
Follow Up By: Member - David P (VIC) - Monday, Apr 07, 2008 at 16:37
tensioner pulley bearing, if there is one?....silverback
FollowupID: 563221
Reply By: Member - Doug T (FNQ) - Monday, Apr 07, 2008 at 16:26
Try with and without A/C on if it squeals with A/C tighten the belt.
AnswerID: 297205
Follow Up By: Member - Dunworkin (WA) - Tuesday, Apr 08, 2008 at 15:40
Hi Doug, we have tried tightening the belt. it is only an annoyance factor, we can hear her coming up the road and it makes people look at you whilst driving along.
Thanks for the reply.
D
FollowupID: 563407
Reply By: Member - John D (VIC) - Monday, Apr 07, 2008 at 16:26
Hi D,
I have a similar problem with my Rodeo TD when I go camping up NSW. After driving around the dusty tracks and stopping for a while, the Rodeo starts screeching when I start up again, I give all the belts & pulleys a squirt of water and then start up again, screeching stops, happens again if I travel over dusty tracks again. Doesn't do it at all when not driving in the dust.
Due for a service soon so will get everything including dust seals checked out then.
Regards,
AnswerID: 297206
Follow Up By: Member - Dunworkin (WA) - Tuesday, Apr 08, 2008 at 15:43
Ha ha ha ha, Hi John D, it does sound funny not being able to take a 4wd on dusty roads. Having said that our daughter hasn't taken hers off the bitumen yet and she has had it for about 18 months.
D
FollowupID: 563408
Reply By: Member -Dodger - Monday, Apr 07, 2008 at 16:42
An old timers trick,
get a cake of soap and with the engine stopped rub the soap on the underside of the belt wherever you can do so, turn the engine over a little then repeat the same then start the engine up and run the squeal should cease.
Cheers Dodg.
AnswerID: 297209
Follow Up By: Member - Dunworkin (WA) - Tuesday, Apr 08, 2008 at 15:46
Hi Dodger, definitely going to remember that one, will give it a try.
It is amazing how well some of those "old timers" tricks work,
D
FollowupID: 563409
Reply By: Member - Bucky (VIC) - Tuesday, Apr 08, 2008 at 06:38
Had exactly the same problem over 2 years back.
Annoyance factor/Service bay $$ maker, on the flat belt.
I am sure its built in
I did myself
Everything off, all bearings good, took off belt tensioner ( mongrel thing ) sprayed Inox on it, put back on ... still squeeling/squeeking..
Alternator off, Inox into the rear of pully
New belt, lots of belt lube,,,,
Only thing left was waterpump,, ( big $$$ I thought )
All of a sudden 3 days later, all stops..?????//
Phew !
Never done anything like it again, still same gear on Navara ?
You tell me ????
Bucky
AnswerID: 297318
Follow Up By: Member - Dunworkin (WA) - Tuesday, Apr 08, 2008 at 15:37
Thanks for that Bucky, will pass all info on.
D
FollowupID: 563405
