using to much oil???
Submitted: Tuesday, Jun 24, 2003 at 23:33
Brian
I own a 1990 jackaroo 2.8 diesel the engine was rebuilt about 12 months afo (10000 k's) I had to top up with 1 ltr of oil after a 2000 k trip and 1/2 ltr after a 700 k trip
am I using to much oil??
The exhaust blows
grey smoke on first start ???
any ideas
Bri
Reply By: Eric - Tuesday, Jun 24, 2003 at 23:45
Brian.
If the motor was rebored and fitted with new valve guides it is burning to much oil, if the motor just had new rings on the old
bore its probably about right as it will take another 20k to bed the rings in. Eric.
23423
Follow Up By: Member - Cocka - Wednesday, Jun 25, 2003 at 17:38
Note for Eric
Eric are you the same person who posted comments re Konig chains (that post is now in archives) a while back.
You indicated access to a source of supply. I'm looking for Konig chains at the moment, size 185/75-R16.
You could reply to cocka2000@optusnet.com.au.
Thanks for any assistance.
Carpe Diem
15693
Follow Up By: Eric - Wednesday, Jun 25, 2003 at 22:18
Cocka.
Not me. Eric
15710
Reply By: Tony - Wednesday, Jun 25, 2003 at 08:37
You may want to use a different grade of oil.
23440
Follow Up By: Brian - Wednesday, Jun 25, 2003 at 12:33
thanks Tony
see bills reply
Brian
15660
Reply By: Bill - Wednesday, Jun 25, 2003 at 09:15
Brian what engine oil are you using?
Our engine had a similar problem at 7000k after rebuilding. Our engine reconditioner suggested changing to
Caltex Delo 400 engine oil which we did and now only put in 200ml at 2000km
23443
Follow Up By: Brian - Wednesday, Jun 25, 2003 at 12:32
thanks Bill
Yes that is the same oil that I use , have used it all the time
did not use that much before rebuild
Brian
15659
Reply By: Member - Bob W - Wednesday, Jun 25, 2003 at 09:32
It does seem high, has it been the same from overhaul or is it improving ?
Did you 'run in engine' ? Do you know if it getting past rings or valve guides -- can be checked easily with compression test -- maybe you have a broken ring from assembly.
Bob W
23446
Follow Up By: Brian - Wednesday, Jun 25, 2003 at 12:38
Thanks Bob
I reckon it has been the same but I did not worry too much as I was making allowences for the bedding in ??/
I do get some oil coming thru the breather
I think I might call and see the firm that organised it all and see what they are offering??
Brian
15661
