gme tx 3440 bad reception
Submitted: Monday, Apr 07, 2008 at 16:30
ThreadID: 56405 Views:2453 Replies:9 FollowUps:3
hi guys,
I have recently installed a new tx 3440 and using a gme 409l 6/9db antenna problem is that when using it i can get perfect reception upto 1klm after this range i cant hear anything? Can some one help with reasons why i cant get any range?
I was told when i cut the coax to fit into fire wall i might have stuffed up the capping of it? would this cause a dramatic loss in receiveing signals
Reply By: Dave B (NSW) - Monday, Apr 07, 2008 at 16:46
I thought the length of cable on an ariel was the length it should be for good reception.
If you cut it , it may not be the same length.
Mine was pretuned for the ariel when I bought it.
'Wouldn't be dead for quids'
AnswerID: 297210
Follow Up By: obee - Monday, Apr 07, 2008 at 18:37
not true
owen
FollowupID: 563237
Reply By: Stu & "Bob" - Monday, Apr 07, 2008 at 17:07
You may have shorted out the co-ax when you re-terminated the PL259 plug. Or the centre wire is broken. Cut the plug off, and start again.
AnswerID: 297216
Follow Up By: Member - Davoe (Yalgoo) - Monday, Apr 07, 2008 at 17:11
yep almost certanly. as said cut the plug off and redo it carefully this time
also wire length doesnt have to be a tuned length with uhf
FollowupID: 563231
Follow Up By: tycune - Monday, Apr 07, 2008 at 18:40
thanks bob and davoe i will cut the plug and redo this time being more carefull hopefully this will fix my reception
FollowupID: 563238
Reply By: MEMBER - Darian (SA) - Monday, Apr 07, 2008 at 17:58
Yep - the local UHF experts told me up to 6m of coax should be trouble free with modern UHF's. Re plugs -I'm a bit of a techno klutz but I test the circuits in the coax (both centre and shield) once the plugs are on, prior to connecting it all up - a cheap multimeter etc can tell you if you have stuffed up somewhere, before you do any damage.
AnswerID: 297227
Reply By: Hopper51 - Monday, Apr 07, 2008 at 17:58
Have you set your squelch correctly?
AnswerID: 297228
Reply By: Patrol_Driver - Monday, Apr 07, 2008 at 18:26
I had the same exact experience and it was one tiny strand of the outer wire shorting when I fitted the plug. Re-fitted the plug and it was all good.
AnswerID: 297234
Reply By: tycune - Monday, Apr 07, 2008 at 18:41
thanks all:)
i will try to redo the plug and hope this will fix the problem i will let you know tomorrow
AnswerID: 297236
Reply By: str- Tuesday, Apr 08, 2008 at 14:09
Hi there,
I have the same set up. be carefull when fitting or removing the aeriel. if you use the black base to twist it on or off it can break the internals of the aerial.
AnswerID: 297377
Reply By: stocky - Tuesday, Apr 08, 2008 at 17:56
Plug on the AE409L is not designed to be re-useable. Buy a new plug and have another go :-)
AnswerID: 297400
Reply By: tycune - Wednesday, Apr 09, 2008 at 21:03
thanks everyone,
Have replaced the existing plug and its amazing wht the difference is. I can now get 20klm line of sight on all channels and atleast now can use repeaters.
I checked the plug with a meter and instead of staying as a open link it showed 0.1 which i found out means it has a short! lol :) and whould have been extremly lucky to have got 1klm. Wish it explained these things happen when you install them rofl
cheers,
tycune
AnswerID: 297673
