Lightforce 240's on Nissan Patrol steel bullbar
Submitted: Tuesday, Apr 08, 2008 at 07:51
ThreadID: 56423 Views:3178 Replies:6 FollowUps:7
Just wondering if lightforce 240's will fit on a new Nissan Patrol factory steell bullbar?
Does anyone have this setup?
Reply By: Member - Roachie (SA) - Tuesday, Apr 08, 2008 at 08:20
Yes they will fit.......but like my XGTs, you will find that they won't exactly fit within the side profile of the bar. IE: when viewed from side-on, the lights will sit slightly forward of the main hoop bar. However, I have never heard of anybody being pinged for this. Given that it is a flat surface, there is no additional harm that could befall a wayward pedestrian when they clobbered by your GU.....in fact, it could be argued, that the light's would present a slightly more attractive front for that person..... I still believe this whole pedestrian-friendly bullbar/front-end thing is totally fanciful: The fact is that if a 2.5tonne truck hits you at anything above about 15k/h, you're gunna be just as D E A D whether it's got a bullbar or inner spring bloody mattress attached to it's front extremities!!!! hahahaa
AnswerID: 297327
Reply By: DARREN - Tuesday, Apr 08, 2008 at 08:27
thanks Roachie, much appreciated, just what I was after. I went for a squiz at your profile pics and saw:
"converted to 55w 6000k HID"
in lay person terms, what does this entail/deliver?
Does that mean you put some techno globes in?
I have not been on this forum for som time, good to see you have chopped your car in half since I was last here!!
thanks again
AnswerID: 297330
Follow Up By: Member - Roachie (SA) - Tuesday, Apr 08, 2008 at 10:18
G'day Darren,
No, I didn't have my original GU chopped and re-motored...this is a different truck altogether.
As for the lights..... I'm not sure how much you understand about HID technology, but my XGTs have been completely re-built (internally) and now have totally different characteristics.
Check out:
http://hid.isclever.com/
and
Site Link
FollowupID: 563369
Reply By: Snowy 3.0iTD - Tuesday, Apr 08, 2008 at 09:56
Darren
I have my Ligthforce 240's mounted on the front of black standard Nissan GU steel bar. The only thing is I had couple of little brackets made as the on my 240 Blitz lights the front rim of the light sits lower than the mounting point. Drew up a sketch with a few measurements and cost me $40 to have them made out of stainless steel, so that they now sit with the back of the lights touching the grill and the front of them does not stick out any further than the front of the bar. This would not be a problem with with the XGT's.
Snowy
AnswerID: 297346
Reply By: Member - Beatit (QLD) - Tuesday, Apr 08, 2008 at 10:30
G'day Darren,
Mine also fit but as mentioned before they sit a little proud of the front of the bar. This is not a bad thing either, the bride recently backed our commodore into the front of the Nissan the only damage was the boot of the dore. Two scalloped imprimts of the light.
My first reaction was $hit hope you didn't break the lights? Not a crack in either the lenses or the mounts my god they are tough.
Kind regards
AnswerID: 297352
Reply By: DARREN - Tuesday, Apr 08, 2008 at 10:32
thanks for the responses guys..
(at the risk of starting WW3 I'll say) I am now off to the Nissan Dealer to replace my 2003 3.0TD which has given me 135,000 of trouble free motoring with another 3 litre...........................
although I will go for the 6 year 150km warranty :-)
AnswerID: 297353
Follow Up By: Member - David P (VIC) - Tuesday, Apr 08, 2008 at 13:38
Its only just run-in, best economy, why trade now?...silverback
FollowupID: 563394
Follow Up By: Leroy - Tuesday, Apr 08, 2008 at 15:15
yeh trade her before she blows ;-)
Leroy
FollowupID: 563402
Follow Up By: DARREN - Tuesday, Apr 08, 2008 at 15:20
says Leroy the 3.0 Driver!
FollowupID: 563403
Follow Up By: Leroy - Tuesday, Apr 08, 2008 at 22:06
Leroy
FollowupID: 563472
Reply By: stocky - Tuesday, Apr 08, 2008 at 18:04
Got a Ute with steel bar & XGT's - yes they stick out a bit - but damn they work well :-)
AnswerID: 297403
Follow Up By: Graham & Lynne - Thursday, May 01, 2008 at 21:37
stocky
What diffuser do you use ? I was going to give the blue combos a go.
From Graham
FollowupID: 567631
Follow Up By: stocky - Thursday, May 01, 2008 at 22:21
Used to run twin "spot" on the LC100 - but have changed to combos since fitting them to the 'Trol and I am very happy with them - good spread close and still good distance as well
FollowupID: 567649
