GU Mirror fix??
Submitted: Tuesday, Apr 08, 2008 at 14:18
Truckster (Vic)
Team...
I read on one
forum somewhere a cure for this but cant find it. Searched here for GU AND Mirror but gave up 5 pages later with nothin to do with GU's or mirrors...
Anyone fixed the rattling mirrors? On
mine its the whole part that the glass mounts in, then onto the small part on the door
Is it an easy fix, or $10,000,000ea from Nissan and back order from
Siberia is the only solution??
Reply By: Member - Roachie (SA) - Tuesday, Apr 08, 2008 at 14:23
There's a small gap (the pivot) between the mirror's body and the door-mount. Get ya'self one or 2 tech screws and use your cordless drill to drive the screws in between
the gap. No more shakey-shakey....
Hahahahahaha
297378
Follow Up By: Truckster (Vic) - Tuesday, Apr 08, 2008 at 14:25
yea thanks mr helpful :P
563398
Reply By: madcow - Tuesday, Apr 08, 2008 at 14:44
interesting problem. I've had that issue for a while and got too looking at getting some rubber sheet and inserting into
the gap. I have read the post you speak about but it may have been on aother
forum. will be watching this thread.
297383
Reply By: Moggs - Tuesday, Apr 08, 2008 at 14:51
mine used to rattle where the mirror casing joined the mount. I fixed it by removing the cover plate underneath the door mount part of the mirror and then tightened the retaining screw. Don't over tighten it or you won't be able to fold the mirror in.
297384
Follow Up By: Member - Glenn D (NSW) - Wednesday, Apr 09, 2008 at 15:16
Mine is the same ,except when you take the bottom cover off there were 3 screws , just took them out 1 at a time ,loctited them and tightened up . no more problems.
Glenn.
563604
Reply By: Member - Fred - Tuesday, Apr 08, 2008 at 14:57
I am pretty sure that if you take the Philips head screw out of the base of the mirror you can access an adjustment to increase the tension on the spring that loads the location cam. Makes it harder to fold mirror back but stops rattle.
297385
Follow Up By: Member - DAZA (QLD) - Tuesday, Apr 08, 2008 at 17:02
I have the same problem with our 15 month old Navara, driver side
mirror, with the auto adjuster. I will get it fixed next service, under
warranty.
Daza
563415
Reply By: Member - Ed. C. (QLD) - Tuesday, Apr 08, 2008 at 19:53
When
mine was loose (and rattling), the fix was as simple as tightening the philips-head screw under the mirror head...
(tightened 'er up nicely;-)) .. The bit that is attached to the door has not been a problem to date.. (YMMV)
I found an off-set screwdriver to be the best way to get at that screw................
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
297427
Follow Up By: Member - Ed. C. (QLD) - Wednesday, Apr 09, 2008 at 21:36
Aaahh yeah,
well ummm..... I lied:(( .. (we'll call it a "senior moment";-))
As mentioned by others, it is indeed the 3 screws under (above?) the cover plate which are tightened to stop the rattle...
as mentioned, said cover is retained by a single philips-head screw under the mirror head...
Been a while since I had to do it, so I guess I musta left my thinkin' cap outside.......................................
| Confucius say.....
563731
Reply By: Member - 'Lucy' - Tuesday, Apr 08, 2008 at 21:19
Nothing a bucket of ULP and a match wouldn't fix.
Also
Doesn't happen on the JEEP
297452
Follow Up By: awill4x4 - Tuesday, Apr 08, 2008 at 22:43
Yep, your right there Lucy, you don't even need a match on the Jeeps, if you drive them up on the
Stockton beach they spontaneously combust.
Regards Andrew.
563486
