Roof rack tie down straps
Submitted: Tuesday, Apr 08, 2008 at 18:53
ThreadID: 56438 Views:4431 Replies:5 FollowUps:4
We are differing in opinions of what straps to use for tying down fuel cans and spare tyre on roof rack - okka straps or the ones with tension etc. Any advice please would be helpful.
Thanks Jinki
Jinki & Harry enjoying !!!!!
Reply By: Member - Kim M (VIC) - Tuesday, Apr 08, 2008 at 19:06
Jinki
GOOD quality ratchet straps with half inch high density rubber under fuel cans.
Kim
AnswerID: 297411
Follow Up By: Crackles - Tuesday, Apr 08, 2008 at 19:18
Agree Kim. You don't want them moving at all.
Cheers Craig.........
FollowupID: 563431
Follow Up By: Member - Matt & Julie (VIC) - Tuesday, Apr 08, 2008 at 20:53
Yes I agree with these guy's you don't want them to move
Matt & Julie
FollowupID: 563448
Reply By: Krakka - Tuesday, Apr 08, 2008 at 19:16
Hi Jinki, go to "Just Straps" website, find on google, on their site put 4wdsts into search. Strap purpose made for spare tyre, plus straps for a million other purposes. Very good quality, aussie made with aussie materials. Have used their cam buckle straps for a tear or so now and very impressed. Don't work loose like the cheaper ones seem to.
Cheers, Krakka
AnswerID: 297413
Reply By: howie - Tuesday, Apr 08, 2008 at 19:32
sometimes use one of those black recycle bins.
think you can get 3 jerrys in, 2 good ratchets holds everything in place.
AnswerID: 297418
Follow Up By: Member - David P (VIC) - Tuesday, Apr 08, 2008 at 19:47
you can, I have. Big black heavy duty plastic rectangular recycle buckets from Bunnings. Lids sold separately...silverback
FollowupID: 563439
Follow Up By: Member - Lance S (VIC) - Tuesday, Apr 08, 2008 at 20:21
Yep, thats how i travel fuel and water, seperately though. 3 in each recycle rectangle bin with 2 very good ratchet straps.
cheers,
Lance
Home Away from Home
FollowupID: 563444
Reply By: mfewster - Tuesday, Apr 08, 2008 at 20:50
Make sure you put carpet or rubber or similar between the cans as well as they can rub against each other and rub through. I use a BIG tube and cut it to the length of the body of the Jerry and pull it over the jerry like a sock. Works beautifully
AnswerID: 297444
Reply By: Member - Jinki & Harry - Tuesday, Apr 08, 2008 at 20:57
Thanks for your help - will use ratchet straps.
Thanks again
Jinki
AnswerID: 297446
