Satellite phone confusion
Submitted: Wednesday, Apr 09, 2008 at 12:53
ThreadID: 56465 Views:3693 Replies:4 FollowUps:46
I have a iridium 9505 sat phone on a $30/m plan
I also have a samsung next G with international roam.
Can and I did put the card from the mobile into the sat phone and that worked.
So does this mean I can get rid of my sat phone plan and just use the mobile sim card and all will work fine.
So this will save me $30 per month on fees for the sat phone and my mobile will be billed only when the card is in the sat phone and used.
IF you know what I mean.
Clear as mud really.
All the best
Eric
Reply By: George_M - Wednesday, Apr 09, 2008 at 13:06
This all depends on how much you use your sat phone.
If you use your Next G sim to make calls then our favourite telephone company will charge you about $4/minute for the privilege.
The per-minute rate charged on the $30/m satellite plan is probably about $2/minute.
George_M
Come any closer and I'll rip your throat out!
AnswerID: 297560
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 13:33
The use dosnt worry me the main question is does it work.
The mobile is on a $600/m cap and when I am away for a month or two it hardley gets used and the sat phone does.
Then when I dont use the sat phone for 4 months or so its costing me $30/m to have it ints case.
All the best
Eric
FollowupID: 563547
Follow Up By: Member - Footloose - Wednesday, Apr 09, 2008 at 13:50
Eric, yes it will. See how it's done in the 9500 phone at Doing the Telstra thing :)
FollowupID: 563548
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 13:58
Thanks I can put the sim from my mobile directy into the sat phone same size card and all.
I did this and it worked fine but what I want to know is can I get rid of the sat phone plan and only have the mobile plan.
All the best
Eric
FollowupID: 563551
Follow Up By: Member - Footloose - Wednesday, Apr 09, 2008 at 14:05
If you're not worried about the incoming and outgoing call costs, yes you can. I usually advise people not to have too many calls coming in if possible, so that they don't end up with a hugeTelstra bill.
You keep your normal number BTW, so it's pretty similar to just using your mobile.
I'll be interested in finding out how the Irridium works on CY.
FollowupID: 563554
Follow Up By: Member - Graham H (QLD) - Wednesday, Apr 09, 2008 at 14:06
In a word YES
but all the calls made on the Sat phone using the sim will be at Satphone rates.
I believe there is also a charge per minute to you if peple ring your mobile and it comes to .you whilst in the Sat phone, which probably wont be covered in your monthly mobile plan.
It will be charged as are premium type calls 0900 etc
FollowupID: 563556
Follow Up By: MrBitchi (QLD) - Wednesday, Apr 09, 2008 at 14:08
Surely if you get rid of your Sat phone plan you'll no longer be able to make Satellite phone calls?? You'll only be able to make NextG calls.
FollowupID: 563558
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 14:11
Graham does that mean I dont need the sat phone plan.
What number does the sat phone get the number on the mobile sim.
The sat phone works very well in the cape.
All the best
Eric
FollowupID: 563563
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 14:13
John thats what i am trying to work out.
All the best
Eric
FollowupID: 563565
Follow Up By: Member - Footloose - Wednesday, Apr 09, 2008 at 14:16
Eric, ditch the sat plan if you're not on a contract. Then use your Telstra SIM from Next G to access the satellite. Call charges are as posted.
Interesting. I thought the canopy would have obscured the satellite in many places on CY?
FollowupID: 563566
Follow Up By: Member - John (Vic) - Wednesday, Apr 09, 2008 at 14:20
The Sat phone WON'T work on the terrestrial Next G Network itself regardless of what Sim card is installed.
The Sat phone works on a different frequency than the Next G phone network.
The Next G Sim card identifies your account with Telstra/Iridium for billing purposes and as said above you will be billed for incoming and outgoing calls at the higher Sat rates.
So you don't need a stand alone Sat plan only Global Roaming on the Next G Sim Card enabled.
FollowupID: 563568
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 14:20
No Im not on a contract.
I used to have a globalstare pain in the butt thing and never really got coverage in the cape.
The iridium has about 5000% better coverage.
All the best
Eric
FollowupID: 563569
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 14:22
Now thats interesting the diference between Footlose answer and Johns answer.
Have either of you done what I am endevouring to do.
All the best
Eric
FollowupID: 563571
Follow Up By: Member - Footloose - Wednesday, Apr 09, 2008 at 14:26
Eric, what I meant to imply is that you would be using your satphone as a mobile by accessing the satellite instead of the terrestrial network.
From your post I presumed that this is what you were asking about....perhaps not ?
FollowupID: 563573
Follow Up By: Member - John (Vic) - Wednesday, Apr 09, 2008 at 14:28
What difference Eric??
I think we both said the same thing and our posts crossed.
FollowupID: 563574
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 14:31
Hi both I might not be very cleaver but I can lift heavy things.
But what does this mean
All the best
Eric
FollowupID: 563577
Follow Up By: Member - Footloose - Wednesday, Apr 09, 2008 at 14:37
Mate, it simply means that your phone will be used as a satellite phone, not as a normal mobile.
Basically it will cost you more for non bush calls that you make around Cairns.
You
FollowupID: 563581
Follow Up By: Member - Footloose - Wednesday, Apr 09, 2008 at 14:38
You can lift heavy things eh? Hernia country :)
FollowupID: 563582
Follow Up By: Member - John (Vic) - Wednesday, Apr 09, 2008 at 14:42
The Sat phone works on a different radio frequency than the Next G network.
The Sat phone cannot talk to the Telstra Next G phone towers/network.
The Sat phone only talks to the Iridium Satellites.
If you HAVE Next G coverage with your Next G phone then don't use the Sim in the Sat phone as it will only access the Sat's at the higher call costs.
If you have NO Next G coverage with your Next G phone then take the Sim out and put it in the Sat phone and you will now have Sat coverage but at the higher call rates both inbound and outbound.
FollowupID: 563584
Follow Up By: Member - John (Vic) - Wednesday, Apr 09, 2008 at 14:44
How heavy a thing can you lift?? :-)
FollowupID: 563585
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 15:15
Very heavy LOL.
All the best
Eric
FollowupID: 563602
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 15:17
So what happens next I suppose I cancel my sat phone plan.
all the best
Eric
FollowupID: 563606
Follow Up By: Member - Footloose - Wednesday, Apr 09, 2008 at 15:22
If you can write off the sat phone calls on tax, why not ?
FollowupID: 563612
Follow Up By: Member - John (Vic) - Wednesday, Apr 09, 2008 at 15:24
Why not test the process for a month to ensure you are happy with the way the call costs pan out??
That way if you don't like what you see you can just put your Sat phone Sim back and keep your accounts the same.
I suggest that as an option as you are in business and need to ensure that your coverage is complete and that you are able to be satisfied with the costs involved.
FollowupID: 563614
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 15:29
I have 3 different businesses to write of expenses.
Its all food for thought
All the best
Eric
FollowupID: 563616
Follow Up By: Member - Graham H (QLD) - Wednesday, Apr 09, 2008 at 15:30
To clarify things
The Motorola 9500,9505 can only talk to Iridium satellites.
If you use the Telstra sim card it still talks only to the satellites and charges your sim at satellite rates.
If someone calls your mobile and your sim is in the satellite phone it will switch thru to it and they get caherged the normal charge to the mobile number and you get charged the difference between that and the satellite rate.
When making outgoing calls you are charged at top dollar sat rates which probaly will be extra to your monthly allowance on your cap mobile plan. Only Ericcson phones on the global Sh**t network can talk to both systems and as you said arent worth having.
No good asking Telstra what to do as they wont guarantee compatibility even tho if you read thru the posts u will see it does work.
And i suppose you do cancel your sat plan AFTER TRYING THE SIM IN THE 9505 TO MAKE SURE IT DOES WORK
FollowupID: 563618
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 15:44
Thanks graham I have put the sim from the mobile in the sat and rang my home number and it worked fine.
Does that mean my sat phone with the mobile sim in it will have my mobile number and then loses the sat number.
All the best
Eric
FollowupID: 563624
Follow Up By: George_M - Wednesday, Apr 09, 2008 at 15:54
Yes.
You can confirm this by leaving your Next G sim in the satphone, and then calling your Next G number from another telephone. The call will go through to the device which has your Next G sim installed.
George_M
FollowupID: 563629
Follow Up By: TD100 - Wednesday, Apr 09, 2008 at 20:23
Eric,
as stated it does work,i have put my swmbo's GSM card with international roaming enabled in my 9500 and it works perfectly,ring her GSM number and sat phone rings.i only use it for trips so minimal use,even at $3.80 odd per minute.saves having 2 contracts/only using 1 once a year.cheers Paul
FollowupID: 563718
Reply By: Big Woody - Wednesday, Apr 09, 2008 at 15:57
Hi Eric,
In a word, Yes, you can drop your Satellite phone plan and just run with the NextG sim card in your Iridium phone.
This is exactly what I have and use. I have a 9505a with no contract and just put my NextG card in the 9505a when it is required. With no contract it means that you are charged the same amount for incoming and outgoing calls - usually about $1.50/minute. I called my brother a few weeks ago to test the rates and it came through on my bill as a 58 second call cost $1.54 and a 62 second call cost $2.02. This just means that they are applying 30 second billing.
In reply to your other question, Yes, the Iridium phone will then assume the phone number of your NextG phone when the card is inserted and people will be able to call you as normal on your NextG number. The difference with no contract is the person calling you will not be charged above normal mobile phone call rates to your number but you will be charged the Satellite call rates for the incoming call and these will all show up on your NextG bill.
I hope this has made sense mate.
Regards,
Brett
AnswerID: 297596
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 16:02
Thanks big Woody thats what I wanted to hear.
So now I call telstra and cancel my sat phone plan. Yes.
All the best
Eric
FollowupID: 563630
Follow Up By: Member - Graham H (QLD) - Wednesday, Apr 09, 2008 at 16:08
Exactly what I said but I didnt know the prices
FollowupID: 563635
Follow Up By: Eric from Cape York Connections - Wednesday, Apr 09, 2008 at 16:10
Thanks Graham Im not real smart but can lift heavy things.
It takes a while to sink in.
All the best
Eric
FollowupID: 563637
Follow Up By: Member - David P (VIC) - Wednesday, Apr 09, 2008 at 17:05
Errrr.....say again.....:)) :))....silverback
FollowupID: 563649
Follow Up By: Member - Fifo - Monday, Apr 14, 2008 at 12:13
Big Woody,
Do you have any idea if the satellite phone rates vary depending upon what NextG plan you are on? I wouldn't think this would alter the rates, but just thought it's a possibility.
Just out of interest, what NextG plan are you on?
Thanks,
FollowupID: 564521
Follow Up By: Member - Graham H (QLD) - Monday, Apr 14, 2008 at 12:41
As stated above up to $3.80 a minute What rate your MOBILE PLAN is, is immaterial as the calls are charged from IRIDIUM via Telstra to your acct regardless of what type it is.
Be aware also that when someone calls your mobile when the sim is in the sat phone, they pay normal to mobile rates and YOU pay the diversion FROM MOBILE TO SAT.
In other words best keep it for emergencies only or get your mates to text you and then you ring them on the mobile.
Its cheaper that way.
FollowupID: 564522
Follow Up By: Member - Graham H (QLD) - Monday, Apr 14, 2008 at 12:42
PS. I cant lift heavy things but I use google a lot.
FollowupID: 564523
Follow Up By: Member - Fifo - Monday, Apr 14, 2008 at 19:00
That's what I thought; thanks for the confirmation.
FollowupID: 564607
Reply By: geocacher (djcache) - Wednesday, Apr 09, 2008 at 23:08
Eric,
What I did to get around the problem of having incoming calls to my normal Next G/GSM phone number incurring $4 a minute calls when people tried to ring me if I had the card in the satphone, was to add another number to my business plan for $10 a month and then put that sim in my Motorola 9500.
That means my Satphone only costs me $120 a year, and I can leave it on when I want to without worrying about getting calls I don't want to pay for. Only a very select few who need to be able to contact me in emergencies have the mobile number I use in the satphone so that they can ring me.
And yes what you want to do works. I've been advocating it for about 4 years.
AnswerID: 297693
Follow Up By: Eric from Cape York Connections - Thursday, Apr 10, 2008 at 06:39
Thanks to all I mucked about with it last night and it all worked fine.
All the best
Eric
FollowupID: 563759
Follow Up By: MrBitchi (QLD) - Thursday, Apr 10, 2008 at 07:35
Does this also work with a non-telstra sim? SWMBO has an Optus account with international roaming...
FollowupID: 563766
Follow Up By: Member - John (Vic) - Thursday, Apr 10, 2008 at 08:15
Nope must be Telstra for account purposes and Optus doesn't work anywhere outback.
FollowupID: 563772
Follow Up By: MrBitchi (QLD) - Thursday, Apr 10, 2008 at 08:18
Bugga :-( HATE dealing with that mob...
FollowupID: 563773
Follow Up By: Eric from Cape York Connections - Thursday, Apr 10, 2008 at 16:42
Well Dave cancelled my sat phone thing today and got a new sim linked to my mobile and got the new number.
I also got me international roam so I cant go wrong now rite.
All the best
Eric
FollowupID: 563844
Reply By: Member - Mike DID - Thursday, Apr 10, 2008 at 11:54
But remember that SMS via Iridium using a Telstra SIM card is still very cheap.
Tell people to SMS you, rather than phone you, when you're outback.
AnswerID: 297744
Follow Up By: Member - Mike DID - Thursday, Apr 10, 2008 at 11:55
P.S. . 9500 can ONLY receive SMS, 9505 can send and receive SMS.
FollowupID: 563809
Follow Up By: Brett007 - Friday, Apr 11, 2008 at 20:08
Does any one know if this works with optus on global roaming as well.
cheers.
FollowupID: 564099
Follow Up By: Member - Graham H (QLD) - Friday, Apr 11, 2008 at 22:00
Yes we do and NO IT WONT as its a Telstra service
Answer was already posted above
FollowupID: 564124
Follow Up By: Member - Mike DID - Sunday, Apr 13, 2008 at 20:16
Telstra is the only Australian mobile phone company that has set up a billing arrangement with Iridium, so that it's costomers can access the Iridium network using a mobile phone simcard.
FollowupID: 564442
Follow Up By: KiwiAngler - Thursday, Apr 17, 2008 at 17:29
Just to stir this 'pot' up again ;-)
I have a Telstra contract phone set up for International roaming and for about 3 years now I have simply removed the Telstra sim card popped it into my Motorola 9505 using Iridium network sat phone and away I go.
Well last week I decided to buy a next g PRE-PAID to replace my now defunct cdma 'spare' phone.
I took the opportunity to set this Telstra pre-paid up for International Roaming also - so that if the Telstra CONTRACT phone ever went walk about I could put the PRE-PAID sim card into the sat phone etc etc.
Well I tried the PRE-PAID sim card couple of nights ago and got the message 'access restricted " so I put my CONTRACT sim card in no problems.
Contacted Telstra and got this message form good old "Mary" from the ??help desk:
quote
Thank you for your email dated 16/4/08 regarding Telstra Mobile Satellite.
We apologize for the inconvenience. Please be advised that Telstra Mobile Satellite (TMS)
is positioned as Telstra's supplement network. It will provide coverage where there is no
Next G/GSM/CDMA network coverage and is subject to satellite service coverage limitations.
Please be informed that TMS is not available on a Prepaid service.
Please do not hesitate to contact us on +61 439 125 109 or via www.telstra.com if you
require further information or assistance.
Thank you.
Yours sincerely,
Mary
Telstra Representative
end quote
So my question is aimed at the ppl using telstra PRE-PAID sim cards in their sat phones - what am I doing wrong??
FollowupID: 565199
