Quick release - rifle position in the 4WD
Submitted: Wednesday, Apr 09, 2008 at 19:35
ThreadID: 56482 Views:6484 Replies:9 FollowUps:13
I have a current model Prado. Looking for Ideas on how to secure a rifle (during hunting on private property). It needs to be in a position that enables quick release.
We had a look at screwing a Troopy grab handle to the dash and securing it with an Ocky strap, but that didn't work.
The only other thing I can think of, is the pillar next to the drivers seat but it would be a mongrel to fix and get to. We're now looking at internal overhead roof options.
PS I don't the money to buy a Troopy.
Kim
Reply By: Member - Keith C (NSW) - Wednesday, Apr 09, 2008 at 19:59
G/day Kim M,how many people in front cab?if you are on your own keep the fire-arm safe till you start to "harvest"!! then you need some-thing like the pros use ,attatched to the drivers door as a rest. Please make sure you point a loaded fire-arm out the window, I have seen a few holes blown thru the roof of holden utes from accidental discharge after driving over bumps. stay safe mate and have a good hunt. Regards Keith C
AnswerID: 297656
Follow Up By: Member - Kim M (VIC) - Wednesday, Apr 09, 2008 at 20:30
Thanks Keith
Normally it's either with a mate or solo. If the mate is in the car it's not a problem, however when alone, the rifle needs to be secured while hunting. The Sako has a bolt lock key which I keep on a chain around my neck.
That's all good an well, but in a shooting situation it's not practical to use. I've been shooting for over fifty years now and well aware of safety issues, but it's good that you reinforce that princlple.
Kim
FollowupID: 563724
Reply By: Peter 2 - Wednesday, Apr 09, 2008 at 20:06
My Humvee came with M16 mounts for each seating position ;-))
Basically all they are is a rectangular bracket on the floor to take the stock and what looks like a Terry clip (spring loaded U shaped clip) on the pillar to hold the barrel.
Maybe you could do something similar.
The 50 cal when not in the pintle on the roof in the turret sits in a bracket beside the front seat passenger on top of the trans tunnel.
AnswerID: 297658
Follow Up By: Ozboc - Thursday, Apr 10, 2008 at 07:19
aaah , thats solves the issue of the 50 cal then !!! cant imagine there is a lot of the bunny left after being it with that monster :)
Boc
FollowupID: 563762
Follow Up By: MrBitchi (QLD) - Thursday, Apr 10, 2008 at 09:42
Bloody handy thing to have in traffic ;-))
FollowupID: 563782
Follow Up By: Ozboc - Thursday, Apr 10, 2008 at 09:44
you recon i can get one mounted to my road bike ????
Boc
FollowupID: 563783
Follow Up By: MrBitchi (QLD) - Thursday, Apr 10, 2008 at 10:20
http://au.youtube.com/watch?v=Nn54FI8h7yQ
FollowupID: 563793
Follow Up By: Peter 2 - Thursday, Apr 10, 2008 at 17:34
Try this one
http://au.youtube.com/watch?v=gMOmLknUnxU
FollowupID: 563862
Reply By: huntin - Wednesday, Apr 09, 2008 at 20:16
Gday, I have a 79 series ute, into which i installed an overhead console designed to fit a scoped (4-12 x 50)rifle. I picked this up on ebay, it was easy to install and keeps the rifle out of sight but easily accessible. The rifle is held in place with an ocky strap type cord which clips over 2 buttons on the front of the console and keeps it snug over any off road or corrugated track. Cheers
AnswerID: 297661
Follow Up By: Member - Kim M (VIC) - Wednesday, Apr 09, 2008 at 20:35
Huntin
Do you have any photographs?
Kim
FollowupID: 563728
Reply By: Member - Bucky (VIC) - Thursday, Apr 10, 2008 at 04:48
Kim
Gone are the days when you can just drill and tap anything, anywhere in vehicles.
Is there anything that you can hang out of the glovebox, and run the stock between the dash, and the steering wheel ?
Problem is that you would have to pad both sides of what ever you used so you don't scratch the shyte out of everything.
I have a D22 Twin Cab Navara, and I secure a gun bag on those "girly/sports bar", with an "ocky" strap, and slide in what ever rifle I so choose to take. Its safe, and dosen't harm the rifle.
It just sits there a treat.
Will work on the same theory for you.
Tell me please, do you get out of the cabin, to take a shot, when on your own ?
Cheers Bucky
AnswerID: 297703
Follow Up By: Member - Kim M (VIC) - Thursday, Apr 10, 2008 at 17:31
Bucky
Yes I do. I use to be able to shoot from either side, but the sight in my left eye is not very good anymore. The left was the side I preferred, whilst shooting out of the window.
Now all shots are taken outside of the car.
Kim
FollowupID: 563859
Reply By: madcow - Thursday, Apr 10, 2008 at 09:30
Do a google on an item called "quick fist". Arb sell them and are also on ebay form the states. Pretty funny name for them but they are the goods.
AnswerID: 297723
Follow Up By: gary - Thursday, Apr 10, 2008 at 11:42
Use 'Quick Fist" to secure my shovel and axe on the wall of the front boot of caravan and they are great..Very secure and so easy to use.
FollowupID: 563808
Follow Up By: Member - Kim M (VIC) - Thursday, Apr 10, 2008 at 17:20
Thanks Madcow
I found a quck release gadget late last night on:
http://www.g-lox.com/huntingproducts.html Model No 06502.
Kim
FollowupID: 563853
Follow Up By: OzTroopy - Thursday, Apr 10, 2008 at 17:55
The G-lox product and similar is available from any reputable firearm store in australia and have been for some considerable time.
It is these products that I based my own, homemade units, on. I didnt mention them as I presumed you had already encountered difficulty, in trying to mount commercially available products.
FollowupID: 563869
Follow Up By: Member - Kim M (VIC) - Thursday, Apr 10, 2008 at 18:28
Oz troopy
Even with G-Lox I'm having trouble finding somewhere to secure the upper bracket on the dash.
I also rang Milford's to see if they had a cargo barrier that could be fitted behind the front seats. No luck.
Were going to pull bits and pieces off the dash over the weekend to find a bit of metal to drill into.
Kim
FollowupID: 563877
Reply By: Member - Wim (Qld) - Thursday, Apr 10, 2008 at 12:29
Kim.
Its been a while but I when I was shooting I made up a leather (thick leather) pouch (scabbard?)to house my 3030 Win.
I had straps on the back to allow me to mount the pouch in various locations.
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 297746
Reply By: OzTroopy - Thursday, Apr 10, 2008 at 13:21
An easily fitted fitted, simple, firearm mount in a modern 4wd in an anti firearm world.
And I thought I had high expectations........LOLOL
Used to be able to get brackets that fitted in the side window frames. Ran a bikelock chain through the trigger guard and every body was happy, even if driving the vehicle round Canberra ( and around and around and around )
If you plan ahead for your feral cleanup trips, this should not be a problem - Hummer style mount on floor area, mounted off seat bolts. Clamp for barrel on dash using solid mounting location. What screws are frame mounted in the glovebox ?
Barrel clamp could be quickfist or even the old style jack handle holders found on earlier 4wds. Go to wreckers with battery drill and drill out spot weld. Can be rivetted, screwed or welded as required.
System worked well horizontally on 40series dash and vertically in Jeep TJ pass door opening. Expect scratching on barrel though.
AnswerID: 297759
Reply By: Moose - Friday, Apr 11, 2008 at 13:51
G'day Kim
Try posting on the forum in Australian Hunting Net.
Cheers from the Moose
AnswerID: 297976
Reply By: Member -Walkabout(NSW) - Thursday, Apr 17, 2008 at 05:28
Kim,
If you are still looking for gun rack ideas...(I'm a bit slow...!!) I have made an overhead console and also a dash mounted quick release cradle for my 'cruiser. I use the overhead console to carry the rifle to and from properties, (out of sight and secure) and use the cradle when shooting. Both of them utilise existing bolt holes, so they are easy to fit and don't destroy the vehicle, and this system doesn't damage the rifle or knock the 'scope. I could take some photo's and send to you if you are interested.
Regards,
Jim
AnswerID: 298966
Follow Up By: Member - Kim M (VIC) - Friday, Apr 18, 2008 at 19:38
Thanks Jim
Send them to kimmc@satlink.com.au
We pulled the dash board apart recently and could'nt find any suitable anchor points.
Kim
FollowupID: 565360
