GU Patrol driveline problem - any ideas?
Submitted: Wednesday, Apr 09, 2008 at 20:25
zigglemeister
Hi all,
Just returned from trying out the new camper trailer on
Bribie Island - had a great time. However I noticed that my GU Patrol (4500 petrol/gas) makes a nasty thump or clunk in the driveline every so often. It's quite irregular; it happened most often in 4H on hard, fast sand - might happen every km or two. It felt to me like it could possibly be the transfer case chain jumping a tooth - is that possible? I did take a tape measure to my tyres and discovered that the fronts are 10 mm bigger in diameter than the rears (much newer, same size but different brands) so I suppose a bit of windup is possible, but I wouldn't have thought it likely on sand??? The other thing that seems weird is that it didn't do it when I got bogged and revved the guts out of it, backwards and forwards trying to get the camper out. (Ended up getting snatched by a Jackaroo, how embarrassment! :-)) Any thoughts, anyone?
Regards,
Tim Z
98 GU Patrol 4500 Petrol/Gas
04 Trackabout Safari camper trailer
Reply By: Member - David P (VIC) - Wednesday, Apr 09, 2008 at 20:31
if your spinning the
wheels I doubt you would get wind-up. Hard packed sand on the other hand ...??...silverback
297666
Reply By: BoldJack ( Penrith NSW) - Wednesday, Apr 09, 2008 at 21:27
"Any thoughts anyone"- mmmm let me see- Get a Jackaroo!!!!
It seems to be a common occurance Jackaroo's snatching Nissan's out of the sand.We have done this before in our Jackaroo.LOL.
297677
Follow Up By: stefan P (Penrith NSW) - Wednesday, Apr 09, 2008 at 21:56
Oh grow up!!! LOL
563736
Reply By: Notso - Wednesday, Apr 09, 2008 at 21:29
The auto hubs can do this I hear.
Check out this
forumhttp://www.patrol4x4.com/forum/forumdisplay.php?f=10
297678
Follow Up By: zigglemeister - Wednesday, Apr 09, 2008 at 22:26
Hi Notso,
The auto hubs were my first thought, so I locked them manually, but the problem still occurred?
Tim
563740
Follow Up By: zigglemeister - Wednesday, Apr 09, 2008 at 22:42
Just tried to get onto that
forum, looks good but I can't register - tells me I have to enter a code from an image for verification, but the image doesn't appear?
Tim
563743
Follow Up By: Notso - Wednesday, Apr 09, 2008 at 22:54
I'm not sure how that code works but on some sites there is a link to click if the code doesn't appear.
563744
Reply By: kiwicol - Friday, Apr 11, 2008 at 18:53
i would be inclined to think your hubs are jumping have had the same problem with manual hubs on my GQ, went through the whole thing checking the hubs no marks on the spline so thought they where fine, checked and greased drive line, finely got to transfer case, and bought second hand job fitted it and still had same prob, ended up replacing hubs and problem fixed. Then had to change transfer out again due to oil leak very expensive lesson, hubs are really cheap. Col
298017
Follow Up By: zigglemeister - Friday, Apr 11, 2008 at 21:32
Thanks very much for that info Col, that's really helpful. Will definitely concentrate on the hubs first!
Regards, Tim
564117
