water in 78 series standard snorkel
Submitted: Thursday, Apr 10, 2008 at 21:32
Troopy(SA)
The other day I was driving in moderately heavy rain and when I stopped though I would check to see if any
water got in through the
snorkel. Had a look and found a bit (maybe 1/4 of a cup) of
water in the bottom of the air filter housing !
The
snorkel is completely standard and I have never had any problems - just wanted to ask if anyone else had experienced this !
Reply By: Stephen M (NSW) - Thursday, Apr 10, 2008 at 22:06
Not sure about your model troopy but when I worked for Toyota 88/92 (pre delivery manager not mechanic) the troopys had the factory snorkels but were in a box inside the vehicle and was part of the pre delivery section to fit them up. The holes etc were already predrilled so just had to push together couple of self tapping screws through the
snorkel to hold together all done, there were bits of foam that was already stuck to the
snorkel joints. Sit the cap on top with a clamp that was it. NO silicone what so ever was applied to any of the joints. I always wondered even back then how we didnt have them come back in with blown motors due to
water been sucked in through the joins. Maybe there were more farm vehicles and never were really dunked in the deep ?? Regards Steve M
297889
Follow Up By: Member - Phil G (SA) - Thursday, Apr 10, 2008 at 22:11
Steve,
The factory snorkels were never designed for
water. Toyota have always called them "dust snorkels". If you want to use it for
water, you need to take them apart and seal them up.
563942
Follow Up By: Stephen M (NSW) - Thursday, Apr 10, 2008 at 22:19
Makes me wonder if the customers were ever told that or I suppose it was up to the customer to ask the question. There you go learn some thing new every day. Worked for them for 4 years and didnt even know the correct name, always thought they were your everyday
snorkel and Toyota just been tight and not wanting to supply some sealant/silicone. Regards Steve M
563945
Follow Up By: Member - Phil G (SA) - Thursday, Apr 10, 2008 at 22:27
The vehicles had a fording depth of 700mm. Thats
well below the
snorkel, so the people in the design office figured there was no need to seal it or make it one piece!
Water can usually get in thru the rubber flaps in the base of the air cleaner box, so if you want to be seriously waterproof, you have to seal that up too, but its nice to have somewhere for the
water to get out!
They have always called it a dust
snorkel - problem is the average customer assumes they are for
water because of the advertising by Safari and Airtech with their one piece aftermarket snorkels.
563947
Follow Up By: samsgoneagain - Friday, Apr 11, 2008 at 00:00
cmon mate 1992 , even you had less wrinkles
563971
Follow Up By: Member - Davoe (Yalgoo) - Friday, Apr 11, 2008 at 14:30
They were prone to splitting as
well.I was bent down doing my shoe up and glanced up at our 75 work ute and noticed in the peice that runs along the front gaurd a split on the underside about 10cm long. Soooooo easy to miss
564052
Reply By: donk - Thursday, Apr 10, 2008 at 22:13
Toyota describe the
snorkel as a dust
snorkel not a
water snorkel & that is why the joints & ducting are not
water tight
Regarding the
water in the aircleaner housing after driving in rain it probably came in with the airflow
Regards Don
297890
Reply By: Member - Phil G (SA) - Thursday, Apr 10, 2008 at 22:13
From memory, theres a rubber flap to let
water out of the bottom of the air cleaner box.
297891
Follow Up By: Member - Doug T (FNQ) - Friday, Apr 11, 2008 at 03:15
100% Correct
563975
Reply By: donk - Thursday, Apr 10, 2008 at 22:16
The new V8
snorkel is probably less wate tight than the old one where it enters through the guard
Regards Don
297895
Reply By: Troopy(SA) - Thursday, Apr 10, 2008 at 22:43
Thanks for the feedback - I have noticed the rubber flap at the bottom of the air cleaner box which would let
water out - question is then with a fully sealed
snorkel how would any
water get out if it got drawn in when driving through heavy rain ?
It's good to know that the standard
snorkel is not suitable for
water crossing greater than around 700mm - will need to seal it up or get a after market one to be sure for
water crossings !
297904
Reply By: Member - 'Lucy' - Thursday, Apr 10, 2008 at 23:07
Thats precisely why one buys and installs a Safari
snorkel with a 'air-ram' head.
297908
Reply By: samsgoneagain - Thursday, Apr 10, 2008 at 23:58
yes. i have a 79 ish ute and air filter light comes on i n heavy rain. strange, but i keep on driving, cause it is driving rain..........
297918
Reply By: Wayne (NSW) - Friday, Apr 11, 2008 at 08:40
Troopy,
If you have a good look at the
snorkel and air filter housing you will see that as the air is drawn down the
snorkel and enters the air box at a angle.
This allows the air to swirl around the air filter housing forcing all the heavy particle's to the out side of the housing. This is one of the reasons that the housing is round.
After the heavy particle's, dust, bugs, grass seeds and rain, have swirled around they will drop to the bottom of the housing and will fall into a sump located on the bottom of the air filter housing.
On the bottom of the sump is a rubber flap with will allow
water to drain out. This sump should be removed and cleaned when the air filter is cleaned.
If you had
water in the bottom of the air filter housing, remove the sump, it might be full or blocked.
Wayne
297946
Reply By: Member - Kiwi Kia - Friday, Apr 11, 2008 at 09:37
Bet your snorkle head faces forward !
297953
Follow Up By: Wayne (NSW) - Friday, Apr 11, 2008 at 09:59
Kiwi Kia,
The standard Toyota
snorkel has a type of pre cleaner and does not have a forward facing head.
The air intake is under the rim of the head and air passes under the rim, through fins that swirl the air before it passes down the
snorkel.
Wayne
564005
Follow Up By: Member - Kiwi Kia - Friday, Apr 11, 2008 at 11:48
Hi Wayne, Yes, you are right, I have a troopy myself.
I did not read the heading properly :-((
"78 series standard snorkle"
564029
Follow Up By: Member - Phil G (SA) - Friday, Apr 11, 2008 at 14:17
Gday Wayne,
I know what you're saying, but funnily enough, theres a big arrow inscribed in the factory head that tells you which way is forward!
I haven't had a closer look to see why. Maybe its possible that Troopy (SA) factory
snorkel head has been put on backwards :-)))
564050
Follow Up By: Wayne (NSW) - Friday, Apr 11, 2008 at 14:41
Phil,
Image Could Not Be Found
It has to go on so that the drain is at the back.
Wayne
564053
