New Caravan trouble in Mt Isa
Submitted: Saturday, Apr 12, 2008 at 11:29
camwill69
Hi All,
My parents are heading to Mt Isa on Monday and are having issues with the plumbing on there new van. Behind the vanity the clip lock pipes have come apart and flooded the van.
Does any one know a repairer in Mt Isa that they can take it to? It is not the first time this has happened with the van having been flooded before while at the manufactures undergoing repairs. It is only 5 months old.
They are heading to the Kimberly's over the next few months and just want it fixed properly.
Any help would be greatly appreciated.
Regards,
Cam
Reply By: Member - Doug T (FNQ) - Saturday, Apr 12, 2008 at 12:16
I don't know what
Park they are in, you didn;\'t say but if they were to book into The
Mount Isa Caravan Pk on the corner of Abel Smith Pde and Marian St (Barkley Hwy) opposite the Overland Hotel I'm the caretaker there will point them in the rifgr direction , he's pretty handy with repairs as it is so he might be able to help ,
HOVI Plumbing Service
149 Simpson St
Mount Isa, QLD 4825
(07) 4743 6617?
Barry Bower's 7 Day Plumbing Service
Mount Isa - Plumbers & Gasfitters
Elizabeth Street
Mount Isa, QLD, 4825
07 4743 0332
Bob Krause Domestic Plumbing & Roofing
Oxide Street
0412 36 1121
298098
Follow Up By: camwill69 - Saturday, Apr 12, 2008 at 14:35
Thanks Doug,
I have passed on this info to the folk's and they may contact you Monday.
They are currently east of
Boulia and will travel to Mt Isa on Monday to get repairs done.
Thanks again Doug.
Regards,
Cam
564196
Follow Up By: camwill69 - Sunday, Apr 13, 2008 at 18:19
Doug,
Am I correct in saying from your comments above that you are the care taker at the above said caravan
park?
I ask as the olds have got to the Isa and booked in at the
park you said and the reception knows no one buy the name of Doug. Do you have an alias or is the above post Bs.
Regards,
Cam
564414
Follow Up By: Member - Doug T (FNQ) - Sunday, Apr 13, 2008 at 18:25
camwill69
NO, MISSED WORD but don't you see where I referred to HE
St (Barkley Hwy) opposite the Overland Hotel I'm (SURE) the caretaker there will point them in the (rifgr = RIGHT ) direction , he's pretty handy with repairs as it is so he might be able to help ,
564417
Follow Up By: camwill69 - Sunday, Apr 13, 2008 at 19:17
Hey Doug,
Now I see the confusion. Thanks for
the tip. They will be there for a few days.
Cam
564432
Follow Up By: Member - Doug T (FNQ) - Sunday, Apr 13, 2008 at 20:13
camwill69
Phew ...thank goodness ..lol
tell to ask about Doug and Dusty.
564441
Reply By: Keith_A (Qld) - Saturday, Apr 12, 2008 at 14:22
Hi Cam - Do you mean the cold/hot
water pipes (blue/black/red) and the clip-in style joinerss?
I have had it happen, but only once - out of about 16 connectors in our off-road van.
Many vans have the blue or black pipe and the clip-in connectors. They are very simple and seal
well, however the mechanism does have one small "trick".
The pipe simply pushes in, but you must ensure you push the pipe through (eg by "feel") the 2 (two) seals.
The first seal is the metal fingers that hold the pipe in place, and the second is the O ring that seals the
water. It is easy to to think the pipe is fitted correctly when it has only clicked into the first "seal" eg the metal fingers that hold the pipe in place. You must ensure the pipe is pushed in further - into the O ring, which does the actual sealing. Use sand paper etc and put a bevel on the leading edge of the pipe helps, and perhaps some food grade canola or olive oil. This will help the pipe to push into the O ring and actually seal properly.
A very simple task to do........................Keith
298111
Follow Up By: camwill69 - Saturday, Apr 12, 2008 at 14:39
Keith,
You are spot on with the description of these clips. I have explained this to the old man (your method), but as the van is not in a spot with mobile service it (the pipe) is not in front of him as i explain it to him.
Thanks for you tips.
Regards,
Cam
564197
Reply By: DIO - Saturday, Apr 12, 2008 at 14:31
Probably staing the obvious, but isn't it a job for the manufacturer. If you take it to a 'non-approved' repairer could you have problems with later warranty claim? I'd be jumping onto the manufacturer (hob nail boots and all) and making absolutely sure that it was totally repaired and not liekly to happen again -m before heading off on any trip.
298114
Follow Up By: camwill69 - Saturday, Apr 12, 2008 at 14:41
DIO,
The manufacturer's work is so poor I would not let them touch it again. They have stuffed it so many times it's not funny. To many issues to be able to post them here. Have contacted the Manufacturer and will follow up if they get back to me.
Regards,
Cam
564198
Reply By: dedabato (SA) - Saturday, Apr 12, 2008 at 16:52
Is it jay..? as I had same problem over and over until fixed by my self....
298123
Follow Up By: camwill69 - Saturday, Apr 12, 2008 at 18:44
No mate not a Jay...?. Much poorer quality than that. But it did cost twice as much.
Don't keep trying to guess the brand as I will not publish it due to pending legal action. Put it this way, I would buy a Jay...? any day of the week compared to this product. Even with the reputation of said.
All the help so far has been great. Much appreciated. Will go a long way to helping them out.
Great to see the AUSSIE spirit is still alive, helping those that are stranded far away from home.
Thanks Again.
Cam
564221
Reply By: Dunaruna - Saturday, Apr 12, 2008 at 17:23
The ends of the John Guest pipes get damaged by the little razor blades inside the fitting. If they are removed and refitted a few times, the clips no longer grab. You will need to cut the end of the pipe off so that the razor blades have a good surface to grab. A bad cut will damage the seal (or not engage the seal, which I think is what has happened here). The cut needs to be clean and square.
298126
Reply By: Keith_A (Qld) - Saturday, Apr 12, 2008 at 20:02
Cam - forgot to mention - to release the pipe from the joiners, you just push the small inner ring in (and hold it there). This expands the metal fingers, and lets the pipe pull free. The suggestion re a clean cut is very true - and may even be the main cause of their problem. Make sure you pass that comment also.
On the subject of poor workmanship, our Supreme is a good example. Wood rot within 11 months of delivery, caused by insufficient sealant when made, and the manufacturer just refused to get involved. ...............Keith
298159
