removing 2"bodylift 100 series
Submitted: Saturday, Apr 12, 2008 at 15:46
rooooboy
HI,
just purschased a 100 series with a body lift, i want to remove the lift, is there anything i have too look out for besides looseing the steering shaft slip joint when lowering the body?
any advice thanks
Reply By: Member - BUNDY BOY (WA) - Saturday, Apr 12, 2008 at 16:04
Rooooboy......you would b about the first to ask about removing a lift.....most want to put one in........in answer to your Q....may have to lower bull bar if it was done
well as most refit bar work to match lift......others will have a better idea im shore..
Cheers Bundy
298116
Follow Up By: rooooboy - Saturday, Apr 12, 2008 at 16:14
no the bullbar has not been lifted there is a big gap looks terrible.
564206
Reply By: Dave from P7OFFROAD Accredited Driver Training - Saturday, Apr 12, 2008 at 22:45
It is possible that the may have lowered the radiator to keep it inline with the fan.
I can;t see that there will be too many problems with going down, i guess that you just need to double check that there isn't too much slack in all the lines that were extended, that could cause them to snag or kink.
Was it engineered?? If so, you may have to get it reengineered...
good luck
298183
Reply By: rooooboy - Sunday, Apr 13, 2008 at 11:45
thanks, no it wasnt engineered.
298248
