OziExplorerCE Development Version 2.03
Submitted: Sunday, Apr 13, 2008 at 10:38
ThreadID: 56581 Views:3269 Replies:7 FollowUps:6
Updated 12th April 2008
Reply By: Member - Paul M (VIC) - Sunday, Apr 13, 2008 at 12:49
Thanks for the heads-up
AnswerID: 298254
Reply By: Member -Signman - Sunday, Apr 13, 2008 at 19:16
Do you suggest removing the OziExplorer2.cfg file before upgrading to the newer version (from the previous ' development version' ) ???
Have you upgraded - is it any better/worse ??
AnswerID: 298316
Follow Up By: The Explorer - Sunday, Apr 13, 2008 at 19:54
Hello
They suggest that you delete the OziExplorer2.cfg file if upgrading from a previous development version so suspect its a good idea (I didn't which may explain a few "crashes" now that you mention it - problem gone now).
Changes in new version are detailed on the webpage. If none of these ring your bell then there may be no real point in updating at this stage. I have updated and customised a few pages (which took a while as options are numerous). My requirements (with respect to OziCE) are relatively simple so I am easily pleased..maybe others with more varied requirements can provide input. All working sweet but its only been 1 day..plus I have new device (MobileMapper 6) so lots of R&D at moment.
FollowupID: 564439
Reply By: Gramps (NSW) - Sunday, Apr 13, 2008 at 20:57
Appearance is quite different to previous version. Will see how it performs tomorrow. All seems ok at the moment.
AnswerID: 298343
Reply By: The Explorer - Tuesday, Apr 15, 2008 at 02:41
Now 2.03a
Development Version 2.03a (April 2008)
Changes
2.03a - Fixed issue with reading old version registration codes.
2.03a - Fixed issue with crashing when going to altitude or speed profile page (please let me know if it still crashes).
2.03a - Fixed problem with the settings manager reading the .key2 file.
2.03a - Added ability to load .loc and .gpx geocaching file formats as waypoints.
AnswerID: 298591
Reply By: Member -Signman - Tuesday, Apr 15, 2008 at 09:08
'Morning Greg
I got around to putting 2.03 in last night. First time it looked a bit dicky. I saved all the data (maps, w/ps etc) off the pda onto the PC.
Wiped all previous Ozi stuff off the pda- then did a fresh install with 2.03.
Reloaded the previous saved data- and away she goes.
Looks a bit busy at this stage. Will have to delete a few of the superflous pages, and a bit of customising.
Have you had luck with yours??
AnswerID: 298622
Follow Up By: The Explorer - Tuesday, Apr 15, 2008 at 10:30
Hello - all seems to be good - I have used it probably for 12 hours in total without any problem. Yes - the default pages are busy alright, a reflection of all the options you have.
As mentioned as far as work goes I have simple needs so I made up a "page file" with only two pages - one is just the map and a small button for creating waypoints at the cursor position and second page has buttons and fields showing UTM/lat long, time, date, GPS on/off, No. Sats, battery power remaining and then all buttons for turning on and of the various menu bars that are normally on the map screen. These buttons are great as I can turn off all the stuff that consumes screen space when on the map page. The rocker button is used to zoom in and out and change pages (important as I have no other button on the map page to cycle between pages).
When i get time will have to make up page files for geocaching ect
FollowupID: 564750
Follow Up By: Member -Signman - Friday, Apr 18, 2008 at 13:03
Hi Greg,
Can ya help me with this one.
I've done a 'button' custom job. this had been transferred to the PDA OK.
Have loaded the file in 'Load Button File' through the 'Load Settings"..
However, it doesn't seem to be keeping the setting as it resorts to the standard button setup when it switch on again??
Ave a good one (and don't get lost).
FollowupID: 565309
Follow Up By: The Explorer - Friday, Apr 18, 2008 at 14:51
Hello - not sure what that is caused by. I was going to suggest it maybe the old version kicking in but you have deleted all that. Short term solution - Can you delete all page files except the one you want to use? If so, does that help?
FollowupID: 565324
Follow Up By: Member -Signman - Friday, Apr 18, 2008 at 15:10
Mate- the page files & page setups are working all good. No probs there.
It's the PDA Hardware Control Buttons thats not being saved ?? I did read somewhere that once you 'Load Button File' you then close down or something, can't remember ???
FollowupID: 565329
Follow Up By: The Explorer - Friday, Apr 18, 2008 at 16:02
OK - sorry. Im not sure. Will keep my eyes open for any mention of issue and solution during my internet wanderings.
FollowupID: 565336
Reply By: The Explorer - Friday, Apr 18, 2008 at 16:09
while we're on the subject...
Development Version 2.03b (17 April 2008)
Changes
2.03b - Fixed settings manager when designing for large screens.
2.03b - Fixed keyboard disappearing when editing waypoints.
2.03b - Faster loading of gpx geocaching files.
2.03b - Parameters on map now realign themselves when map is "Expanded".
2.03b - added check for valid "Data File Path" folder, if it is not valid a message is shown.
AnswerID: 299198
Reply By: The Explorer - Tuesday, Apr 22, 2008 at 15:41
Development Version 2.03c (22 April 2008)
Changes
2.03c - Fixed lock-up problem when saving configuration.
2.03c - Added speed, heading and altitude to track replay.
2.03c - Added UTC option for all times.
2.03c - Fixed scale for Pocket PC VGA pda's.
2.03c - Fixed Edit Position "position format" selection.
2.03c - Edit box focus is not lost when keyboard is activated.
2.03c - Added missing keyboard button to Project Wp dialog.
2.03c - Fixed disappearing keyboard button when new name search file loaded.
2.03c - Increased font size on toolbars for Pocket PC's.
AnswerID: 299857
