couple of tyre and wheel questions
Submitted: Sunday, Apr 13, 2008 at 11:32
ThreadID: 56584 Views:2393 Replies:2 FollowUps:3
goodday people
q1 changing wheels to a set of steel wheels from nissan mags Do i need a new set of wheel nuts to suit sunraiser wheels
q2 tyres have done 65000ks about another 15000 left i reckon rear tyres are worn more than the front at this point is it worth changing front to rear to try for more wear
these tyres are the goodyear wranglers i put on in june 06 and have never been touched since and they are still wearing well
steve
Reply By: Member - David P (VIC) - Sunday, Apr 13, 2008 at 11:38
rear tyres are more susceptible to puncture, that why I put most tread on back.....silverback
AnswerID: 298246
Follow Up By: Heefers - Sunday, Apr 13, 2008 at 11:43
Which is alright off road but if the majority of the driving is going to be on road then I'd want the good tyres on the front for better braking and control in an accident avoidance situation.
Just my two bob, Heefers
FollowupID: 564352
Reply By: Robin Miller - Sunday, Apr 13, 2008 at 11:49
Most need new wheels nuts as they have a conical or slopped self centering fit into the steel wheels.
Nissan alloys factory and aftermarket have had a couple of different wheel face flanges , some wheels having steel inserts and some just alloy.
THink nuts are about $8 each from Nissan and I used these as they are lighter than the much cheaper aftermarket items.
In part 2 the wheels should be rotated every 5k or so , so I put them on the front.
On my car I rotate the tyre on the rim as well
AnswerID: 298249
Follow Up By: Member - Nev (TAS) - Sunday, Apr 13, 2008 at 12:06
Hi Robin,
I agree with rotating tyres for even wear but why do you rotate the tyre as well?
Rgds
Nev
FollowupID: 564354
Follow Up By: Robin Miller - Sunday, Apr 13, 2008 at 14:39
Hi Nev
On live axle cars like Patrols the normal rotation stills leaves a bias to wear on the outside of tyres.
Normally I only rotate tyre on the wheel once when its getting later on in its life and it becomes obvious that tread is not as thick on outside as per inside , usually balance them at this point as well.
I had 100,000km on my Patrols 235/85/16 toyo opats before I retired them to my trailer , so it works for me.
FollowupID: 564373
